ArcGIS.Core.Geometry Namespace / SpatialReference Class / AreEqual Method
The first spatial reference.
The spatial reference to compare to.
If set to true and if one SpatialReference is Unknown and the other is not, the two will be considered the same. Default value is false.
Default value is false. If set to true and the resolutions are not equal, false will be returned.
    AreEqual Method (SpatialReference)
    Determines if two spatial references are equal.
    Syntax
    Public Shared Function AreEqual( _
       ByVal sr1 As SpatialReference, _
       ByVal sr2 As SpatialReference, _
       Optional ByVal ignoreUnknown As Boolean, _
       Optional ByVal checkResolution As Boolean _
    ) As Boolean
    Parameters
    sr1
    sr2
    ignoreUnknown
    checkResolution
    Return Value
    True if the two spatial references are the same.
    Requirements
