ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / CreateSpatialReference Method / CreateSpatialReference(Int32,Int32) Method
The well-known ID that represents the Spatial Reference.
The vertical coordinate system well-known ID.
Example
    Convenience method to create a new instance of the SpatialReference class.
    Syntax
    public static SpatialReference CreateSpatialReference(
       int wkid,
       int vcsWkid
    Public Overloads Shared Function CreateSpatialReference( _
       ByVal wkid As Integer, _
       ByVal vcsWkid As Integer _
    ) As SpatialReference
    Parameters
    wkid
    vcsWkid
    Return Value
    Example
    Construct a SpatialReference with a vertical coordinate system - from well-known IDs
      // Use a builder convenience method or use a builder constructor.
      // see a list of vertical coordinate systems at http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Vertical_coordinate_systems/02r3000000rn000000/
      // Builder convenience methods don't need to run on the MCT.
      // 4326 = GCS_WGS_1984
      // 115700 = vertical WGS_1984
      SpatialReference sr4326_115700 = SpatialReferenceBuilder.CreateSpatialReference(4326, 115700);
      // SpatialReferenceBuilder constructors need to run on the MCT.
      await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, 115700))
          // SpatialReferenceBuilder properties
          //   sb.wkid == 4326
          //   sb.Wkt == "GEOGCS["MyGCS84",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT[\"Radian\",1.0]]"
          //   sb.name == GCS_WGS_1984
          //   sb.vcsWkid == 115700
          //   sb.VcsWkt == "VERTCS["WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PARAMETER["Vertical_Shift",0.0],PARAMETER["Direction",1.0],UNIT["Meter",1.0]]
          // do something with the builder
          sr4326_115700 = sb.ToSpatialReference();
    Import and Export Spatial Reference
      SpatialReference srWithVertical = SpatialReferenceBuilder.CreateSpatialReference(4326, 6916);
      string xml = srWithVertical.ToXml();
      SpatialReference importedSR = SpatialReferenceBuilder.FromXml(xml);
      // importedSR.Wkid = 4326
      // importedSR.VcsWkid = 6916
      string json = srWithVertical.ToJson();
      importedSR = SpatialReferenceBuilder.FromJson(json);
    Determine Transformations
      // methods need to run on the MCT
        // find the first transformation used between spatial references 4267 and 4326
        SpatialReference sr4267 =
             SpatialReferenceBuilder.CreateSpatialReference(4267);
        SpatialReference sr4326 = SpatialReferences.WGS84;
        List<ProjectionTransformation> transformations =
               ProjectionTransformation.FindTransformations(sr4267, sr4326);
        // transformations.Count = 1
        ProjectionTransformation projTrans = transformations[0];
        CompositeGeographicTransformation compositeGT =
             projTrans.Transformation as CompositeGeographicTransformation;
        GeographicTransformation gt = compositeGT[0];
        // gt.Wkid = 15851
        // gt.Name = "NAD_1927_To_WGS_1984_79_CONUS"
        // gt.IsForward = true
        // find the first five transformation used between spatial references 4267 and 4326
        transformations = ProjectionTransformation.FindTransformations(
                                           sr4267, sr4326, numResults: 5);
        // transformations.Count = 5
        compositeGT = projTrans.Transformation as CompositeGeographicTransformation;
        // compositeGT.Count = 1
        // compositeGT[0].Wkid = 15851
        // compositeGT[0].Name = "NAD_1927_To_WGS_1984_79_CONUS"
        // compositeGT[0].IsForward = true
        projTrans = transformations[1];
        // compositeGT[0].Wkid = 1173
        // compositeGT[0].Name = "NAD_1927_To_WGS_1984_4"
        projTrans = transformations[2];
        // compositeGT[0].Wkid = 1172
        // compositeGT[0].Name = "NAD_1927_To_WGS_1984_3"
        projTrans = transformations[3];
        // compositeGT.Count = 2
        // compositeGT[0].Wkid = 1241
        // compositeGT[0].Name = "NAD_1927_To_NAD_1983_NADCON"
        // compositeGT[1].Wkid = 108190
        // compositeGT[1].Name = "WGS_1984_(ITRF00)_To_NAD_1983"
        // compositeGT[1].IsForward = false
        projTrans = transformations[4];
        // compositeGT[1].Wkid = 1515
        // compositeGT[1].Name = "NAD_1983_To_WGS_1984_5"
        // compositeGT[1].IsForward = true
        // references 4267 and 4326 within Alaska
        // Alaska
        Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(-161, 61, -145, 69);
                                                    sr4267, sr4326, envelope);
        // compositeGT[0].Wkid = 1243
        // compositeGT[0].Name = "NAD_1927_To_NAD_1983_Alaska"
        // find the first geographic transformation used between two spatial references with VCS  (use vertical = false)
        SpatialReference inSR =
                        SpatialReferenceBuilder.CreateSpatialReference(4269, 115702);
        SpatialReference outSR =
                        SpatialReferenceBuilder.CreateSpatialReference(4326, 3855);
        // Even though each spatial reference has a VCS,
        // vertical = false should return geographic transformations.
        transformations = ProjectionTransformation.FindTransformations(inSR, outSR);
        // compositeGT[0].Wkid = 108190
        // compositeGT[0].Name = ""WGS_1984_(ITRF00)_To_NAD_1983"
        // compositeGT[0].IsForward = false
        // find the first vertical transformation used between two spatial references with VCS  (use vertical = true)
        transformations =
                                          inSR, outSR, vertical: true);
        CompositeHVDatumTransformation compositeHV =
                projTrans.Transformation as CompositeHVDatumTransformation;
        // compositeHV.Count = 2
        // compositeHV[0].Wkid = 1188
        // compositeHV[0].Name = "NAD_1983_To_WGS_1984_1"
        // compositeHV[0].IsForward = true
        // compositeHV[1].Wkid = 110019
        // compositeHV[1].Name = "WGS_1984_To_WGS_1984_EGM2008_2.5x2.5_Height"
        // compositeHV[1].IsForward = true
    Requirements
