public static SpatialReference CreateSpatialReference( string wkt )
Public Overloads Shared Function CreateSpatialReference( _ ByVal wkt As String _ ) As SpatialReference
Parameters
- wkt
- The well-known text that represents the spatial reference.
// Use a builder convenience method or use a builder constructor.
string wkt = "GEOGCS[\"MyGCS84\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Radian\",1.0]]";
// SpatialReferenceBuilder convenience methods don't need to run on the MCT.
SpatialReference sr = SpatialReferenceBuilder.CreateSpatialReference(wkt);
// SpatialReferenceBuilder constructors need to run on the MCT.
await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
using (SpatialReferenceBuilder builder = new SpatialReferenceBuilder(wkt))
// do something with the builder
SpatialReference anotherSR = builder.ToSpatialReference();
// Custom PCS, Predefined GCS
string customWkt = "PROJCS[\"WebMercatorMile\",GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Mercator_Auxiliary_Sphere\"],PARAMETER[\"False_Easting\",0.0],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",0.0],PARAMETER[\"Standard_Parallel_1\",0.0],PARAMETER[\"Auxiliary_Sphere_Type\",0.0],UNIT[\"Mile\",1609.344000614692]]";
// Builder convenience methods don't need to run on the MCT.
SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(customWkt);
// SpatialReferenceBuilder properties
// spatialReference.Wkt == customWkt
// spatialReference.Wkid == 0
// spatialReference.VcsWkid == 0
// spatialReference.GcsWkid == 4326
SpatialReference gcs = spatialReference.Gcs;
// gcs.Wkid == 4326
// gcs.IsGeographic == true
// spatialReference.GcsWkt == gcs.Wkt
using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(customWkt))
spatialReference = sb.ToSpatialReference();
SpatialReference sr = SpatialReferences.WebMercator;
// Get Esri WKT
string wkt = sr.Wkt;
PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
PRIMEM["Greenwich", 0.0],
UNIT["Degree", 0.0174532925199433]],
PROJECTION["Mercator_Auxiliary_Sphere"],
PARAMETER["False_Easting", 0.0],
PARAMETER["False_Northing", 0.0],
PARAMETER["Central_Meridian", 0.0],
PARAMETER["Standard_Parallel_1", 0.0],
PARAMETER["Auxiliary_Sphere_Type", 0.0],
UNIT["Meter", 1.0]]
// Get OGC WKT2
string wkt2 = sr.GetWkt2(WktFormatMode.None);
PROJCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
BASEGEOGCRS["GCS_WGS_1984",
DYNAMIC[FRAMEEPOCH[1990.5], MODEL["AM0-2"]],
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984", 6378137.0, 298.257223563, LENGTHUNIT["Meter", 1.0]]],
PRIMEM["Greenwich", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
CS[ellipsoidal, 2],
AXIS["Latitude (lat)", north, ORDER[1]],
AXIS["Longitude (lon)", east, ORDER[2]],
CONVERSION["Mercator_Auxiliary_Sphere",
METHOD["Mercator_Auxiliary_Sphere"],
PARAMETER["False_Easting", 0.0, LENGTHUNIT["Meter", 1.0]],
PARAMETER["False_Northing", 0.0, LENGTHUNIT["Meter", 1.0]],
PARAMETER["Central_Meridian", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
PARAMETER["Standard_Parallel_1", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
PARAMETER["Auxiliary_Sphere_Type", 0.0]],
CS[Cartesian, 2],
AXIS["Easting (X)", east, ORDER[1]],
AXIS["Northing (Y)", north, ORDER[2]],
// You can create a spatial reference with the Esri WKT string or the OCG WKT2 string
sr = SpatialReferenceBuilder.CreateSpatialReference(wkt2);
// Get OGC WKT2 including authority in top-level objects
// In this case the authority is written as ID["EPSG",3857]
wkt2 = sr.GetWkt2(WktFormatMode.AuthorityTop);
DYNAMIC[FRAMEEPOCH[1990.5],MODEL["AM0-2"]],
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0]]],
PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
CS[ellipsoidal,2],
AXIS["Latitude (lat)",north,ORDER[1]],
AXIS["Longitude(lon)",east,ORDER[2]],
PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0]],
PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0]],
PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
PARAMETER["Auxiliary_Sphere_Type",0.0]],
CS[Cartesian,2],
AXIS["Easting (X)",east,ORDER[1]],
AXIS["Northing (Y)",north,ORDER[2]],
LENGTHUNIT["Meter",1.0],
ID["EPSG",3857]]
// Get OGC WKT2 including authority in all objects
// Authority is written as ID["ESPG",<id>] or ID["Esri",<id>]
wkt2 = sr.GetWkt2(WktFormatMode.AuthorityAll);
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["EPSG",7030]],
ID["EPSG",6326]],
PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",8901]],
CS[ellipsoidal,2],
ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",4326]],
METHOD["Mercator_Auxiliary_Sphere",ID["Esri",43104]],
PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100001]],
PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100002]],
PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100010]],
PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100025]],
PARAMETER["Auxiliary_Sphere_Type",0.0,ID["Esri",100035]]],
CS[Cartesian,2],
AXIS["Easting(X)",east,ORDER[1]],
ID["EPSG",3857]]
// Get datum of a spatial reference
SpatialReference srWgs84 = SpatialReferences.WGS84;
Datum datum = srWgs84.Datum;
// datum.Name = "D_WGS_1984"
// datum.Wkid = 6326
// datum.SpheroidName = "WGS_1984"
// datum.SpheroidWkid = 7030
// datum.SpheroidFlattening = 0.0033528106647474805
// datum.SpheroidSemiMajorAxis = 6378137.0
// datum.SpheroidSemiMinorAxis = 6356752.3142451793
// Custom WKT
string wyomingWkt = "PROJCS[\"Wyoming_State_Pl_NAD_1927\",GEOGCS[\"GCS_North_American_1927\",DATUM[\"D_North_American_1927_Perry\",SPHEROID[\"Clarke_1866_Chase\",6378210.0,250.0]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"false_easting\",500000.0],PARAMETER[\"false_northing\",0.0],PARAMETER[\"central_meridian\",-107.3333333],PARAMETER[\"scale_factor\",0.9999412],PARAMETER[\"latitude_of_origin\",40.66666667],UNIT[\"Foot_US\",0.3048006096012192]]";
SpatialReference srFromWkt = SpatialReferenceBuilder.CreateSpatialReference(wyomingWkt);
// datum.Name = "D_North_American_1927_Perry"
// datum.Wkid = 0
// datum.SpheroidName = "Clarke_1866_Chase"
// datum.SpheroidWkid = 0
// datum.SpheroidFlattening = 0.004
// datum.SpheroidSemiMajorAxis = 6378210.0
// datum.SpheroidSemiMinorAxis = 6352697.16
