ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / CreateSpatialReference Method / CreateSpatialReference(String,Int32) Method
The well-known text that represents the spatial reference.
The vertical coordinate system well-known ID.
    Convenience method to create a new instance of the SpatialReference class.
    Syntax
    public static SpatialReference CreateSpatialReference(
       string wkt,
       int vcsWkid
    Public Overloads Shared Function CreateSpatialReference( _
       ByVal wkt As String, _
       ByVal vcsWkid As Integer _
    ) As SpatialReference
    Parameters
    wkt
    vcsWkid
    Return Value
    Exceptions
    ExceptionDescription
    Requirements
