public SpatialReference ToSpatialReference()
Public Function ToSpatialReference() As SpatialReference
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Use a builder convenience method or use a builder constructor.
// SpatialReferenceBuilder convenience methods don't need to run on the MCT.
SpatialReference sr3857 = SpatialReferenceBuilder.CreateSpatialReference(3857);
// SpatialReferenceBuilder constructors need to run on the MCT.
await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
using (SpatialReferenceBuilder srBuilder = new SpatialReferenceBuilder(3857))
// do something with the builder
sr3857 = srBuilder.ToSpatialReference();
string wkt = "GEOGCS[\"MyGCS84\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Radian\",1.0]]";
SpatialReference sr = SpatialReferenceBuilder.CreateSpatialReference(wkt);
using (SpatialReferenceBuilder builder = new SpatialReferenceBuilder(wkt))
SpatialReference anotherSR = builder.ToSpatialReference();
// see a list of vertical coordinate systems at http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Vertical_coordinate_systems/02r3000000rn000000/
// Builder convenience methods don't need to run on the MCT.
// 4326 = GCS_WGS_1984
// 115700 = vertical WGS_1984
SpatialReference sr4326_115700 = SpatialReferenceBuilder.CreateSpatialReference(4326, 115700);
using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, 115700))
// SpatialReferenceBuilder properties
// sb.wkid == 4326
// sb.Wkt == "GEOGCS["MyGCS84",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT[\"Radian\",1.0]]"
// sb.name == GCS_WGS_1984
// sb.vcsWkid == 115700
// sb.VcsWkt == "VERTCS["WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PARAMETER["Vertical_Shift",0.0],PARAMETER["Direction",1.0],UNIT["Meter",1.0]]
sr4326_115700 = sb.ToSpatialReference();
// custom VCS - use vertical shift of -1.23 instead of 0
string custom_vWkt = @"VERTCS[""SHD_height"",VDATUM[""Singapore_Height_Datum""],PARAMETER[""Vertical_Shift"",-1.23],PARAMETER[""Direction"",-1.0],UNIT[""Meter"",1.0]]";
SpatialReference sr4326_customVertical = SpatialReferenceBuilder.CreateSpatialReference(4326, custom_vWkt);
// sr4326_customVertical.wkid == 4326
// sr4326_customVertical.vert_wkid == 0
// sr4326_customVertical.vert_wkt == custom_vWkt
// sr4326_customVertical.hasVcs == true
using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, custom_vWkt))
sr4326_customVertical = sb.ToSpatialReference();
// Custom PCS, Predefined GCS
string customWkt = "PROJCS[\"WebMercatorMile\",GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Mercator_Auxiliary_Sphere\"],PARAMETER[\"False_Easting\",0.0],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",0.0],PARAMETER[\"Standard_Parallel_1\",0.0],PARAMETER[\"Auxiliary_Sphere_Type\",0.0],UNIT[\"Mile\",1609.344000614692]]";
SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(customWkt);
// spatialReference.Wkt == customWkt
// spatialReference.Wkid == 0
// spatialReference.VcsWkid == 0
// spatialReference.GcsWkid == 4326
SpatialReference gcs = spatialReference.Gcs;
// gcs.Wkid == 4326
// gcs.IsGeographic == true
// spatialReference.GcsWkt == gcs.Wkt
using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(customWkt))
spatialReference = sb.ToSpatialReference();
// use the builder constructor
// spatial reference builder properties
int builderWkid = srBuilder.Wkid;
string builderWkt = srBuilder.Wkt;
string builderName = srBuilder.Name;
double xyScale = srBuilder.XYScale;
double xyTolerance = srBuilder.XYTolerance;
double xyResolution = srBuilder.XYResolution;
Unit unit = srBuilder.Unit;
double zScale = srBuilder.ZScale;
double zTolerance = srBuilder.ZTolerance;
Unit zUnit = srBuilder.ZUnit;
double mScale = srBuilder.MScale;
double mTolerance = srBuilder.MTolerance;
double falseX = srBuilder.FalseX;
double falseY = srBuilder.FalseY;
double falseZ = srBuilder.FalseZ;
double falseM = srBuilder.FalseM;
// get the spatial reference
SpatialReference sr3857 = srBuilder.ToSpatialReference();
// spatial reference properties
int srWkid = sr3857.Wkid;
string srWkt = sr3857.Wkt;
string srName = sr3857.Name;
xyScale = sr3857.XYScale;
xyTolerance = sr3857.XYTolerance;
xyResolution = sr3857.XYResolution;
unit = sr3857.Unit;
zScale = sr3857.ZScale;
zTolerance = sr3857.ZTolerance;
zUnit = sr3857.ZUnit;
mScale = sr3857.MScale;
mTolerance = sr3857.MTolerance;
falseX = sr3857.FalseX;
falseY = sr3857.FalseY;
falseZ = sr3857.FalseZ;
falseM = sr3857.FalseM;
bool hasVcs = sr3857.HasVcs;
