ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / Domain Property
    Domain Property (SpatialReferenceBuilder)
    Gets or sets the valid extent of this coordinate system. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Envelope Domain {get; set;}
    Public Property Domain As Envelope
    Property Value
    Envelope representing the domain of the spatial reference. The envelope returned is useful as a limit for zooming out on a map with this spatial reference.
    Exceptions
    ExceptionDescription
    Remarks
    The extent returned is the bounding box of the valid area of this spatial reference and might not mean that a point within this extent is a valid point in the spatial reference. If the spatial reference has z-precision or m-precision, then the z- and m-domains will also be included. Note that the domain must be a square. If you set values such that the input envelope is not a square, the larger of the width and height will take precedence. For example, let's say you set XMin = -180, YMin = -90, XMax = 180, and YMax = 90. If you then get the domain, you will see that YMax = 270. That is because the width = 360, so the height must also equal 360. The minimum x and y values are always maintained.
    Requirements
