ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / MScale Property
Example
    MScale Property (SpatialReferenceBuilder)
    Gets or sets the M Scale. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public double MScale {get; set;}
    Public Property MScale As Double
    Exceptions
    ExceptionDescription
    Example
    SpatialReference Properties
      // SpatialReferenceBuilder constructors need to run on the MCT.
      await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        // use the builder constructor
        using (SpatialReferenceBuilder srBuilder = new SpatialReferenceBuilder(3857))
          // spatial reference builder properties
          int builderWkid = srBuilder.Wkid;
          string builderWkt = srBuilder.Wkt;
          string builderName = srBuilder.Name;
          double xyScale = srBuilder.XYScale;
          double xyTolerance = srBuilder.XYTolerance;
          double xyResolution = srBuilder.XYResolution;
          Unit unit = srBuilder.Unit;
          double zScale = srBuilder.ZScale;
          double zTolerance = srBuilder.ZTolerance;
          Unit zUnit = srBuilder.ZUnit;
          double mScale = srBuilder.MScale;
          double mTolerance = srBuilder.MTolerance;
          double falseX = srBuilder.FalseX;
          double falseY = srBuilder.FalseY;
          double falseZ = srBuilder.FalseZ;
          double falseM = srBuilder.FalseM;
          // get the spatial reference
          SpatialReference sr3857 = srBuilder.ToSpatialReference();
          // spatial reference properties
          int srWkid = sr3857.Wkid;
          string srWkt = sr3857.Wkt;
          string srName = sr3857.Name;
          xyScale = sr3857.XYScale;
          xyTolerance = sr3857.XYTolerance;
          xyResolution = sr3857.XYResolution;
          unit = sr3857.Unit;
          zScale = sr3857.ZScale;
          zTolerance = sr3857.ZTolerance;
          zUnit = sr3857.ZUnit;
          mScale = sr3857.MScale;
          mTolerance = sr3857.MTolerance;
          falseX = sr3857.FalseX;
          falseY = sr3857.FalseY;
          falseZ = sr3857.FalseZ;
          falseM = sr3857.FalseM;
          bool hasVcs = sr3857.HasVcs;
    Requirements
