ArcGIS.Core.Geometry Namespace / SpatialReferences Class / WebMercator Property
Example
    Gets a Web Mercator (WKID = 3857) spatial reference object.
    Syntax
    Public Shared ReadOnly Property WebMercator As SpatialReference
    public static SpatialReference WebMercator {get;}
    Example
    Import and Export Geometries to well-known Text
      // create a point with z, m
      MapPoint point = MapPointBuilderEx.CreateMapPoint(
               100, 200, 300, 400, SpatialReferences.WebMercator);
      // set the flags
      WktExportFlags wktExportFlags = WktExportFlags.WktExportDefaults;
      WktImportFlags wktImportFlags = WktImportFlags.WktImportDefaults;
      // export and import
      string wktString = GeometryEngine.Instance.ExportToWKT(wktExportFlags, point);
      MapPoint importPointGeom = GeometryEngine.Instance.ImportFromWKT(
            wktImportFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
      double x = importPointGeom.X;       // x = 100
      double y = importPointGeom.Y;       // y = 200
      bool hasZ = importPointGeom.HasZ;   // hasZ = true
      double z = importPointGeom.Z;       // z = 300
      bool hasM = importPointGeom.HasM;   // hasM = true
      double m = importPointGeom.M;       // m = 400
      // export without z
      WktExportFlags exportFlagsNoZ = WktExportFlags.WktExportStripZs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ, point);
      hasZ = importPointGeom.HasZ;  // hasZ = false
      z = importPointGeom.Z;        // z = 0
      // export without m
      WktExportFlags exportFlagsNoM = WktExportFlags.WktExportStripMs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoM, point);
      hasM = importPointGeom.HasM;  // hasM = false
      m = importPointGeom.M;        // m = Nan
      // export without z, m
        exportFlagsNoZ | exportFlagsNoM, point);
    Project from WGS84 to WebMercator
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0, SpatialReferences.WGS84);
      Geometry result = GeometryEngine.Instance.Project(pt, SpatialReferences.WebMercator);
      MapPoint projectedPt = result as MapPoint;
    Requirements
