ArcGIS.Core.Geometry Namespace / Unit Class / ConversionFactor Property
Example
    Gets the conversion factor of the unit.
    Syntax
    Public Overridable ReadOnly Property ConversionFactor As Double
    public virtual double ConversionFactor {get;}
    Remarks
    Conversion factor is defined as follows:
    Linear: meters per unit.
    Area: square meters per unit.
    Angular: radians per unit. Grid: Always 0. There is no way to convert between grid units.
    Example
    AngularUnit - Create an AngularUnit with a factory code
      try
        // create a Grad unit
        var grad = AngularUnit.CreateAngularUnit(9105);
        string unitName = grad.Name;                        // Grad
        double conversionFactor = grad.ConversionFactor;    // 0.015708
        double radiansPerUnit = grad.RadiansPerUnit;
        int factoryCode = grad.FactoryCode;                 // 9105
        // convert 10 grads to degrees
        double val = grad.ConvertTo(10, AngularUnit.Degrees);
        // convert 10 radians to grads
        val = grad.ConvertFromRadians(10);
      catch (ArgumentException)
        // ArgumentException will be thrown by CreateAngularUnit in
        // the following scenarios:
        // - if the factory code used is a non-angular factory code
        //   (i.e. it corresponds to square meters which is an area unit code)
        // - if the factory code used is invalid
        //   (i.e. it is negative or doesn't correspond to any factory code)
    LinearUnit - Create a LinearUnit with a factory code
      try
        // create a british 1936 foot
        var britFoot = LinearUnit.CreateLinearUnit(9095);
        string unitName = britFoot.Name;                        //  "Foot_British_1936"
        double conversionFactor = britFoot.ConversionFactor;    // 0.3048007491
        double metersPerUnit = britFoot.MetersPerUnit;
        int factoryCode = britFoot.FactoryCode;                 // 9095
        // convert 10 british 1936 feet to centimeters
        double val = britFoot.ConvertTo(10, LinearUnit.Centimeters);
        // convert 10 m to british 1936 feet
        val = britFoot.ConvertFromMeters(10);
        // ArgumentException will be thrown by CreateLinearUnit
        // in the following scenarios:
        // - if the factory code used is a non-linear factory code
    LinearUnit - Create a Custom LinearUnit
      // create a custom linear unit - there are 0.33 meters per myLinearUnit
      var myLinearUnit = LinearUnit.CreateLinearUnit("myCustomLinearUnit", 0.33);
      string name = myLinearUnit.Name;                          // myCustomLinearUnit
      double convFactor = myLinearUnit.ConversionFactor;        // 0.33
      int code = myLinearUnit.FactoryCode;                      // 0 for custom units
      double metersUnit = myLinearUnit.MetersPerUnit;           // 0.33
      string toString = myLinearUnit.ToString();                // same as Name - myCustomLinearUnit
      // convert 10 centimeters to myLinearUnit
      double convertedVal = LinearUnit.Centimeters.ConvertTo(10, myLinearUnit);
      // get the wkt
      string lu_wkt = myLinearUnit.Wkt;
      // create an angular unit from this wkt
      var anotherLinearUnit = LinearUnit.CreateLinearUnit(lu_wkt);
      // anotherLinearUnit.ConversionFactor = 0.33
      // anotherLinearUnit.FactoryCode = 0
      // anotherLinearUnit.MetersPerUnit = 0.33
    Requirements
