ArcGIS.Desktop.Core Namespace / EsriHttpResponseMessage Class
Members Example
    Provides a class representing HTTP response message.
    Object Model
    EsriHttpResponseMessage ClassEsriHttpResponseMessage Class
    Syntax
    Public Class EsriHttpResponseMessage
    public class EsriHttpResponseMessage
    Remarks
    HTTP response messages are received by the client from the server after an HTTP request messages is sent.
    Example
    EsriHttpClient: Get the Current signed on User
      //Reference Newtonsoft - Json.Net
      //Reference System.Net.Http
      UriBuilder selfURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/portals/self",
        Query = "f=json"
      EsriHttpResponseMessage response = new EsriHttpClient().Get(selfURL.Uri.ToString());
      dynamic portalSelf = JObject.Parse(await response.Content.ReadAsStringAsync());
      // if the response doesn't contain the user information then it is essentially
      // an anonymous request against the portal
      if (portalSelf.user == null)
        return;
      string userName = portalSelf.user.username;
    Get the Groups for the Current Signed on User
      //Assume that you have executed the "Get the Current signed on User" snippet and have 'userName'
      UriBuilder groupsURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = String.Format("sharing/rest/community/users/{0}", signOnUserName),
        Query = "f=json"
      var groupResponse = new EsriHttpClient().Get(groupsURL.Uri.ToString());
      dynamic portalGroups = JObject.Parse(await groupResponse.Content.ReadAsStringAsync());
      string groups = portalGroups.groups.ToString();
    EsriHttpClient: Query for esri content on the active Portal
      //http://www.arcgis.com/sharing/search?q=owner:esri&f=json
      UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/search",
        Query = "q=owner:esri&f=json"
      EsriHttpClient httpClient = new EsriHttpClient();
      var searchResponse = httpClient.Get(searchURL.Uri.ToString());
      dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
      long numberOfTotalItems = resultItems.total.Value;
      long currentCount = 0;
      List<dynamic> resultItemList = new List<dynamic>();
      // store the first results in the list
      resultItemList.AddRange(resultItems.results);
      currentCount = currentCount + resultItems.num.Value;
      //Up to 50
      while (currentCount < numberOfTotalItems && currentCount <= 50)
        searchURL.Query = String.Format("q=owner:esri&start={0}&f=json", resultItems.nextStart.Value);
    EsriHttpClient: Get a Web Map for the Current User and Add it to Pro
        Query = "f=json"
      EsriHttpResponseMessage response = httpClient.Get(searchURL.Uri.ToString());
        return;
      searchURL.Path = "sharing/rest/search";
      string webMaps = "(type:\"Web Map\" OR type:\"Explorer Map\" OR type:\"Web Mapping Application\" OR type:\"Online Map\")";
      searchURL.Query = string.Format("q=owner:{0} {1}&f=json", userName, webMaps);
      if (numberOfTotalItems == 0)
        return;
      //get the first result
      dynamic item = resultItemList[0];
      string itemID = item.id;
      Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
      if (MapFactory.Instance.CanCreateMapFrom(currentItem))
        Map newMap = MapFactory.Instance.CreateMapFromItem(currentItem);
        await ProApp.Panes.CreateMapPaneAsync(newMap);
    EsriHttpClient: Get a Service Layer and Add it to Pro
      string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
      //any public layer content
      searchURL.Query = string.Format("q={0}&f=json", layers);
        return;
      await QueuedTask.Run(() =>
        //Create a LayerCreationParam
        var layerParam = new LayerCreationParams(currentItem);
        // if we have an item that can be turned into a layer
        // add it to the map
        if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
          LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, MapView.Active.Map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Core.EsriHttpResponseMessage
    Requirements
