ArcGIS.Desktop.Core Namespace / Item Class / GetItems Method
Example
    GetItems Method (Item)
    Browses the contents of an item. Returns a snapshot collection of of the item's children. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetItems() As IEnumerable(Of Item)
    public IEnumerable<Item> GetItems()
    Return Value
    Returns an enumerable collection of items
    Exceptions
    ExceptionDescription
    Remarks
    For example, returns a list of all the feature datasets, feature classes, tables and so on within a database. Or, returns a list of all the subfolders and other items within a folder.
    Example
    Get Project Items by ProjectItem type
      // Get all the items that can be accessed from a folder connection. The items immediately
      // contained by a folder, that is, the folder's children, are returned including folders
      // and individual items that can be used in ArcGIS Pro. This method does not return all
      // items contained by any sub-folder that can be accessed from the folder connection.
      FolderConnectionProjectItem folderConnection = Project.Current.GetItems<FolderConnectionProjectItem>()
                                                          .FirstOrDefault(folder => folder.Name.Equals("Data"));
      //Note: Needs QueuedTask to run
      IEnumerable<Item> folderContents = folderConnection.GetItems();
    Obtaining Geodatabase from Project Item
      await QueuedTask.Run(() =>
        IEnumerable<GDBProjectItem> gdbProjectItems = Project.Current.GetItems<GDBProjectItem>();
        foreach (GDBProjectItem gdbProjectItem in gdbProjectItems)
          using (Datastore datastore = gdbProjectItem.GetDatastore())
            //Unsupported datastores (non File GDB and non Enterprise GDB) will be of type UnknownDatastore
            if (datastore is UnknownDatastore)
              continue;
            Geodatabase geodatabase = datastore as Geodatabase;
            // Use the geodatabase.
    Requirements
