ArcGIS.Desktop.Core.Geoprocessing Namespace / Geoprocessing Class / ShowMessageBox Method
Pass messages from the result (IGPResult) of ExecuteToolAsync to be shown on the message box.
Header of the messages.
Geoprocessing message box style, for example, GPMessageBoxStyle.Default or GPMessageBoxStyle.Error
Title at the top bar of the message box.
Path to a icon image to be shown next to content header.
Example
    Shows a messag box with Geoprocessing messages as formatted for the message box.
    Syntax
    Public Shared Sub ShowMessageBox( _
       ByVal messages As IEnumerable(Of IGPMessage), _
       ByVal content_header As String, _
       ByVal style As GPMessageBoxStyle, _
       Optional ByVal window_title As String, _
       Optional ByVal icon_source As String, _
       Optional ByVal parentViewModel As ViewModelBase _
    Parameters
    messages
    content_header
    style
    window_title
    icon_source
    parentViewModel
    Example
    How to pass parameter with multiple or complex input values
      var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      string toolName = "Snap_edit";  // or use edit.Snap
      // Snap tool takes multiple inputs each of which has
      // Three (3) parts: a feature class or layer, a string value and a distance
      // Each part is separated by a semicolon - you can get example of sytax from the tool documentation page
      var snapEnv = @"'C:/SnapProject/fgdb.gdb/line_1' END '2 Meters';'C:/SnapProject/fgdb.gdb/points_1' VERTEX '1 Meters';'C:/SnapProject/fgdb.gdb/otherline_1' END '20 Meters'";
      var infc = @"C:/SnapProject/fgdb.gdb/poly_1";
      var snapParams = Geoprocessing.MakeValueArray(infc, snapEnv);
      GPExecuteToolFlags tokens = GPExecuteToolFlags.RefreshProjectItems | GPExecuteToolFlags.GPThread | GPExecuteToolFlags.AddToHistory;
      IGPResult snapResult = Geoprocessing.ExecuteToolAsync(toolName, snapParams, environments, null, null, tokens).Result;
      // use the result as needed
    How to use Geoprocessing public event
      ArcGIS.Desktop.Core.Events.GPExecuteToolEvent.Subscribe(e =>
              // Handle the event
              string id = e.ID;           // Same as history ID
              if (e.IsStarting == false)  // Execute completed
                _ = e.GPResult.ReturnValue;
              System.Windows.MessageBox.Show("event triggered.");
      Geoprocessing.ExecuteToolAsync("management.GetCount", Geoprocessing.MakeValueArray(@"c:\shape_file.shp"));
    Requirements
