// Attach an event handler to receive notifications when a row in the selected // table is changed. The subscription targets the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> found in // the active map. Use this method to monitor and respond to edits made to table records within the current map // context. Table thisTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable(); RowChangedEvent.Subscribe(rowChangedEventArgs => { // set the current row changed guid when you execute the Row.Store method // used for re-entry checking Guid _currentRowChangedGuid = new(); // RowEvent callbacks are always called on the QueuedTask so there is no need // to wrap your code within a QueuedTask.Run lambda. var row = rowChangedEventArgs.Row; // check for re-entry (only if row.Store is called) if (_currentRowChangedGuid == rowChangedEventArgs.Guid) return; var fldIdx = row.FindField("POLICE_DISTRICT"); if (fldIdx != -1) { //Validate any change to �police district� // cancel the edit if validation on the field fails if (row.HasValueChanged(fldIdx)) { // cancel edit with invalid district (5) var value = row["POLICE_DISTRICT"].ToString(); if (value == "5") { //Cancel edits with invalid �police district� values rowChangedEventArgs.CancelEdit($"Police district {row["POLICE_DISTRICT"]} is invalid"); } } // update the description field row["Description"] = "Row Changed"; // this update with cause another OnRowChanged event to occur // keep track of the row guid to avoid recursion _currentRowChangedGuid = rowChangedEventArgs.Guid; row.Store(); _currentRowChangedGuid = Guid.Empty; } }, thisTable);
