ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / GetTemplates Method
The map member to retrieve templates from.
Example
    GetTemplates Method (MappingExtensions)
    Gets all templates for a map member. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetTemplates( _
       ByVal mapMember As MapMember _
    ) As IList(Of EditingTemplate)
    public static IList<EditingTemplate> GetTemplates(
       MapMember mapMember
    Parameters
    mapMember
    Return Value
    A list of templates.
    Exceptions
    ExceptionDescription
    Remarks
    If called on the MCT and templates are not yet loaded the templates will load and be returned. See also AreTemplatesLoaded
    Example
    Find table templates belonging to a standalone table
    // retrieve editing templates associated with standalone tables in the active map.
    await QueuedTask.Run(() =>
      //Get a particular table template
      var tableTemplate = activeMap.FindStandaloneTables("Address Points").FirstOrDefault()?.GetTemplate("Residences");
      //Get all the templates of a standalone table
      var ownersTableTemplates = activeMap.FindStandaloneTables("Owners").FirstOrDefault()?.GetTemplates();
      var statisticsTableTemplates = activeMap.GetStandaloneTablesAsFlattenedList().First(l => l.Name.Equals("Trading Statistics")).GetTemplates();
    Activate template and its default editing tool
      // Get all templates for the layer
      var templates = featureLayer.GetTemplates();
      if (templates.Count == 0)
        return;
      // Get the first template - alternatively get a specific template
      var template = templates.First();
      // Activate the default tool
      template.ActivateDefaultToolAsync();
    Activate template and a specific editing tool
        // DAML ID of the tool to activate - for example "esri_editing_SketchTwoPointLineTool" Pro Tool or a custom tool
        string _editToolname = "esri_editing_SketchTwoPointLineTool";
          return;
        // Confirm the tool is available in the template
        if (template.ToolIDs.FirstOrDefault(_editToolname) == null)
          return;
        // Activate the tool
        template.ActivateToolAsync(_editToolname);
    Activate template and its last selected tool
          return;
        // Activate the last selected/used tool for the template
        template.ActivateLastSelectedToolAsync();
    Activate template without changing current tool
          return;
        // Activate the template without changing the current tool
        template.ActivateAsync();
    Hide or show editing tools on templates
         //hide all tools except line tool on a given feature layer
         var editTemplates = featureLayer.GetTemplates();
         var newCIMEditingTemplates = new List<CIMEditingTemplate>();
         foreach (var et in editTemplates)
           //initialize template by activating default tool
           et.ActivateDefaultToolAsync();
           var cimEditTemplate = et.GetDefinition();
           //get the visible tools on this template
           var allTools = et.ToolIDs.ToList();
           //add the hidden tools on this template
           allTools.AddRange(cimEditTemplate.GetExcludedToolIDs().ToList());
           //hide all the tools then allow the line tool
           cimEditTemplate.SetExcludedToolIDs(allTools.ToArray());
           cimEditTemplate.AllowToolID("esri_editing_SketchLineTool");
           newCIMEditingTemplates.Add(cimEditTemplate);
         //update the layer templates
         var layerDef = featureLayer.GetDefinition() as CIMFeatureLayer;
         // Set AutoGenerateFeatureTemplates to false for template changes to stick
         layerDef.AutoGenerateFeatureTemplates = false;
         layerDef.FeatureTemplates = newCIMEditingTemplates.ToArray();
         featureLayer.SetDefinition(layerDef);
    Requirements
