Add Feature Class To Terrain (3D Analyst Tools)
Summary
Adds one or more feature classes to a terrain dataset.
Usage
  • Input features must reside in the same feature dataset as the terrain dataset.
  • Terrain dataset must already have one or more pyramid levels defined.
  • Depending on the surface type associated with features added to a terrain, the terrain dataset may need to be rebuilt using Build Terrain. The terrain dataset's Properties dialog box in ArcCatalog and the terrain layer's Properties dialog box in ArcMap both provide an indication as to whether the dataset needs to be rebuilt.
  • Consider enabling the overview option for breakline and polygon surface feature types only if the features contain simplified geometry and are visually relevant for the anticipated display scale. For example, breaklines may not be visible enough to matter at an overview display, whereas a clip polygon would be useful. If the boundary feature is detailed, consider generalizing it and use the coarser representation for the overview. The detailed version should be used at display scales more suited for its resolution of detail.
  • For terrain datasets stored in an enterprise geodatabase:
    • The target terrain cannot be registered as versioned.
    • The input feature class cannot be registered as versioned.
Parameters
Label Explanation Data type
Input Terrain
The terrain to which feature classes will be added. The terrain dataset must already have one or more pyramid levels created.
Terrain Layer
Input Feature Class
Identifies features being added to the terrain. Each feature must reside in the same feature dataset as the terrain and have its role defined through the following properties:
Value table columns:
  • Input Features—Name of the feature class being added to the terrain.
  • Height Field—Field containing the feature's height information.
  • Type—The way the input future contributes to the terrain surface.
    • Mass Points—Points that are used for triangulation.
    • Hard Line—Linear features that represent sharp discontinuities in elevation.
    • Soft Line—Linear features that represent a gradual discontinuity in elevation.
    • Hard Clip—Polygon feature that defines the interpolation zone with sharp discontinuities at the edges.
    • Soft Clip—Polygon feature that defines the interpolation zone with gradual discontinuities at the edges.
    • Hard Erase—Polygon feature that defines the area to be treated as having no data. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Erase—Polygon feature that defines the area to be treated as having no data. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
    • Hard Replace—Polygon feature that defines a constant z-value for all mass points within the boundary. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Replace—Polygon feature that defines a constant z-value for all mass points within the boundary. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
    • Hard Value Fill—Polygon feature that defines a constant z-value within its boundary. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Value Fill—Polygon feature that defines a constant z-value within its boundary. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
  • Group—Defines the group of each contributing feature.
  • Min Resolution—The lowest resolution that the surface feature will be enforced.
  • Max Resolution—The highest resolution that the surface feature will be enforced.
  • Overview—Indicates whether the feature is enforced at the coarsest representation of the terrain dataset.
  • Embed—Checking this option indicates the source features will be copied to a hidden feature class that will be referenced by and only available to the terrain.
  • Embed Name—Name of the embedded feature class.
  • Embed Fields—Specifies Blob field attributes to be retained in the embedded feature class.
  • Anchor—Specifies whether the point feature class will be anchored through all terrain pyramid levels.
Value Table
Derived output
Updated Input Terrain
The updated terrain.
Terrain Layer
Environments
Current Workspace, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
