Change Terrain Reference Scale (3D Analyst Tools)
Summary
Changes the reference scale associated with a terrain pyramid level.
Usage
  • Consider changing a terrain pyramid's reference scale if you experience undesirable draw speed performance or require greater densification of data points in the pyramid's display scale range.
  • It may also be necessary to add or remove a pyramid level when changing the resolution of an existing one, which can be done by using Add Terrain Pyramid or Remove Terrain Pyramid.
  • When used in an SDE database, the input terrain cannot be registered as versioned.
Parameters
Label Explanation Data type
Input Terrain
The terrain dataset that will be processed.
Terrain Layer
Old Reference Scale
The reference scale of an existing pyramid level.
Long
New Reference Scale
The new reference scale for the pyramid level.
Long
Derived output
Updated Input Terrain
The updated terrain.
Terrain Layer
Environments
Current Workspace, Scratch Workspace, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
