Change Terrain Resolution Bounds (3D Analyst Tools)
Summary
Changes the pyramid levels at which a feature class will be enforced for a given terrain dataset.
Usage
  • Pyramid resolution bounds can only be assigned for surface types that are not designated as masspoints.
  • Consider adjusting the resolution bounds for a terrain feature when new pyramids are introduced or its current range provides undesirable display performance.
  • The terrain dataset will not be invalidated from this operation and will not need to be rebuilt with the Build Terrain tool.
Parameters
Label Explanation Data type
Input Terrain
The terrain dataset that will be processed.
Terrain Layer
Input Feature Class
The feature class referenced by the terrain that will have its pyramid-level resolutions modified.
String
Lower Pyramid Resolution
(Optional)
The new lower pyramid-level resolution for the chosen feature class.
Double
Upper Pyramid Resolution
(Optional)
The new upper pyramid-level resolution for the chosen feature class.
Double
Contributes to Overview
(Optional)
Specifies whether the feature class will contribute to the overview of the terrain dataset.
  • Checked—Enforces the feature class at the overview display of the terrain dataset. This is the default.
  • Unchecked—Omits the feature class from the overview display of the terrain dataset.
Boolean
Derived output
Updated Input Terrain
The updated terrain.
Terrain Layer
Environments
Current Workspace, Scratch Workspace, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
