Inside 3D (3D Analyst Tools)
Summary
Determines if 3D features from an input feature class are contained inside a closed multipatch, and writes an output table recording the features that are partially or fully inside the multipatch.
Illustration
Inside 3D tool graphic
Usage
  • All input features must have Z information stored as part of their geometry. If field based height measurements are present in a 2D feature class, the Feature To 3D By Attribute tool can be used to create a 3D feature class.
  • Closed multipatch geometry is required for this analysis. The Is Closed 3D tool can be used to determine if a multipatch feature class contains closed features, and the Enclose Multipatch tool can be used to eliminate gaps in multipatch features.
  • If the Complex Output Table option is selected, a record is created for each multipatch that a given input feature intersects. A feature may fall within multiple closed multipatch features and have multiple entries in the output table.
  • The following fields are present in the output table:
    • Target_ID—The unique ID of the input feature.
    • Status—Indicates if the feature identified by the Target_ID field is inside or partially inside a multipatch.
    • Contain_ID—Identifies the unique ID of the multipatch that intersects the input features are inside or partially inside. Only included if the Complex Output Table option is selected
Parameters
Label Explanation Data type
Input Features
The input multipatch or 3D point, line, or polygon feature class.
Feature Layer
Input Multipatch Features
The closed multipatch features that will be used as the containers for the input features.
Feature Layer
Output Table
The output table providing a list of 3D features in the Input Features parameter value that are inside or partially inside the Input Multipatch Features parameter value which are closed. The output table contains an OBJECTID (object ID), Target_ID, and Status field. The Status field will state if the input feature (Target_ID) is inside or partially inside a multipatch.
Table
(Optional)
Specifies whether the output table will identify the relationship between the Input Features and the Input Multipatch Features parameter values through the creation of a Contain_ID field that identifies the multipatch feature that contains the input feature.
  • Checked—The multipatch feature that contains an input feature will be identified.
  • Unchecked—The multipatch feature that contains an input feature will not be identified. This is the default.
Boolean
Environments
Current Workspace, Output CONFIG Keyword, Auto Commit, Extent
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
