LAS Point Statistics By Area (3D Analyst Tools)
Summary
Evaluates the statistics of LAS points that overlay the area defined by polygon features.
Usage
  • You can filter the LAS dataset's points by classification codes, classification flags, return values, and elevation range. Define point filters on the LAS dataset's Layer Properties dialog box or using the Make LAS Dataset Layer tool.
  • Consider using this tool to determine the characteristics of lidar points over regions of interest defined by polygon boundaries. Only elevation obtained from LAS points will be evaluated. Any Z-values contributed by surface constraint features referenced by the LAS dataset will be ignored.
  • This tool adds several fields to the attribute table of the input features. If the fields already exist, their values will be overwritten. The values in the updated fields will reflect the indicated statistics about LAS points that overlap the input feature:
    • Z_MIN—The lowest Z-value.
    • Z_MAX—The highest Z-value.
    • Z_MEAN—The average Z-value.
    • POINT_COUNT—The tally of LAS points that were evaluated.
    • STD_DEV—The standard deviation of Z-values.
Parameters
Label Explanation Data type
Input LAS Dataset
The LAS dataset that will be processed.
LAS Dataset Layer
Input Polygons
The polygon that defines the area for which statistics will be reported.
Feature Layer
Output Property
The properties that will be calculated.
  • Minimum Z—The lowest Z value of LAS points overlapping the feature.
  • Maximum Z—The highest Z value of LAS points overlapping the feature.
  • Average Z—The average Z value of LAS points overlapping the feature.
  • LAS Point Count—The tally of LAS points that were evaluated.
  • Standard Deviation—The standard deviation of Z values.
String
Derived output
Updated Input Polygons
The updated input polygon features.
Feature Class
Environments
Current Workspace
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
