Locate LAS Points By Proximity (3D Analyst Tools)
Summary
Identifies LAS points within the three-dimensional proximity of z-enabled features along with the option to reclassify those points.
Usage
  • This tool updates the input feature with a field that contains the count of LAS points that fall within the specified search radius. There is no limit to the number of points that can be generated by this tool, so consider avoiding the use of extremely large search distances.
  • You can filter the LAS dataset's points by classification codes, classification flags, return values, and elevation range. Define point filters on the LAS dataset's Layer Properties dialog box or using the Make LAS Dataset Layer tool.
  • When generating the output point feature using single point geometry, a field named DIST3D will be added to the output that will contain the 3D distance from the point to the nearest input feature.
Parameters
Label Explanation Data type
Input LAS Dataset
The LAS dataset that will be processed.
LAS Dataset Layer
Input 3D Features
The 3D point, line, polygon, or multipatch features whose proximity will be used for identifying LAS points.
Feature Layer
Search Radius
The distance around the input features that will be evaluated for the presence of LAS points, which can be provided as either a linear distance or a numeric field in the input feature's attribute table. If the search radius is derived from a field or a linear distance whose units are specified as Unknown, the linear unit of the input features' XY spatial reference is used.
Linear Unit; Field
Count Field
The name of the field that will be added to the input feature's attribute table and populated with the number of LAS points in each feature's proximity. The default field name is COUNT.
String
Output Feature Class
(Optional)
The point features that represent the LAS points detected within the specified proximity of the input features.
Feature Class
Output Geometry Type
(Optional)
Specifies the geometry of the output point features that represent the LAS points found within the specified proximity of the input features.
  • Multipoint—Multipoint features that will have multiple points in each row.
  • Point—Single-point features that will have a unique row for each identified LAS point.
String
New Class Code
(Optional)
The class code value that will be used to reclassify the points found within the search radius of the input features.
Long
Compute statistics
(Optional)
Specifies whether statistics will be computed for the .las files referenced by the LAS dataset. Computing statistics provides a spatial index for each .las file, which improves analysis and display performance. Statistics also enhance the filtering and symbology experience by limiting the display of LAS attributes, such as classification codes and return information, to values that are present in the .las file.
  • Checked—Statistics will be computed. This is the default.
  • Unchecked—Statistics will not be computed.
Boolean
Update pyramid
(Optional)
Specifies whether the LAS dataset pyramid will be updated after the class codes are modified.
  • Checked—The LAS dataset pyramid will be updated. This is the default.
  • Unchecked—The LAS dataset pyramid will not be updated.
Boolean
Derived output
Updated Input LAS Dataset
The updated LAS dataset.
LAS Dataset Layer
Updated Input 3D Features
The updated input 3D features.
Feature Layer
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output XY Domain, Output Z Domain, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
