Reclass by Table (3D Analyst Tools)
Summary
Reclassifies (or changes) the values of the input cells of a raster using a remap table.
Usage
  • The input raster must have valid statistics. If the statistics do not exist, you can create them using the Calculate Statistics tool in the Data Management toolbox.
  • The From value field, To value field, and Output value field are the field names in the table that define the remapping.
  • To reclassify individual values, use a simple remap table of two items. The first item identifies the value to reclassify, and the other item identifies the value to assign to it. Set the To value field the same as the From value field. The value to assign to the output is Output value field.
  • To reclassify ranges of values, the remap table must have items defining the start and end of each range, along with the value to assign the range. The item defining the start of the range is the From value field, and the value defining the end of the range is the To value field. The value to assign to the output is Output value field.
  • The remap table can be a geodatabase table, a text file, or a dbase file.
  • The values in the from and to fields can be any numerical item. The assignment values in the output field must be integers.
  • Values in the From value field for .dbf and Geodatabase tables do not need to be sorted. For text-file based tables, they must be sorted in ascending order. The values should not overlap in either case.
Parameters
Label Explanation Data type
Input raster
The input raster to be reclassified.
Raster Layer
Input remap table
Table holding fields defining value ranges to be reclassified and the values they will become.
Table View
From value field
Field holding the beginning value for each value range to be reclassified.
This is a numeric field of the input remap table.
Field
To value field
Field holding the ending value for each value range to be reclassified.
Field
Output value field
Field holding the integer values to which each range should be changed.
This is an integer field of the input remap table.
Field
Output raster
The output reclassified raster.
The output will always be of integer type.
Raster Dataset
Change missing values to NoData
(Optional)
Denotes whether missing values in the reclass table retain their value or get mapped to NoData.
  • Checked—Signifies that if any cell location on the input raster contains a value not present or reclassed in a remap table, the value will be reclassed to NoData for that location on the output raster.
  • Unchecked—Signifies that if any cell location on the input raster contains a value not present or reclassed in a remap table, the value should remain intact and be written for that location to the output raster. This is the default.
Boolean
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires 3D Analyst or Spatial Analyst
  • Standard: Requires 3D Analyst or Spatial Analyst
  • Advanced: Requires 3D Analyst or Spatial Analyst
