Remove Feature Class From Terrain (3D Analyst Tools)
Summary
Removes reference to a feature class participating in a terrain dataset.
Usage
This tool will only delete embedded features referenced by a terrain dataset.
The terrain may need to be rebuilt using Build Terrain if the features being removed were referenced as masspoints surface type. Both the terrain dataset's Properties dialog box in ArcCatalog and the terrain layer's Properties dialog box provide an indication as to whether the dataset needs to be rebuilt.
When used in an SDE database, the input terrain cannot be registered as versioned.
Parameters
| Label | Explanation | Data type |
Input Terrain |
The terrain dataset that will be processed. |
Terrain Layer |
Input Feature Class |
The feature class to be removed. |
String |
Derived output
Updated Input Terrain |
The updated terrain. |
Terrain Layer |
Environments
Current Workspace, Scratch Workspace, Auto Commit
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
