Replace Terrain Points (3D Analyst Tools)
Summary
Replaces points referenced by a terrain dataset with points from a specified feature class.
Usage
The terrain data source can be points, multipoints, or embedded points.
The replacement points can come from single-point or multipoint features.
Replacing points in a terrain dataset will invalidate it. Run Build Terrain after adding points or multipoints.
Parameters
| Label | Explanation | Data type |
Input Terrain |
The terrain dataset that will be processed. |
Terrain Layer |
Input Terrain Data Source |
The name of the terrain point feature class that will have some or all of its points replaced. |
String |
Input Points |
The point or multipoint features that will replace the terrain point features. |
Feature Layer |
Area of Interest (Optional) |
An optional area of interest can be used to define the extent of the area in which the terrain points would be replaced. |
Feature Layer; Extent |
Derived output
Updated Input Terrain |
The updated input terrain. |
Terrain Layer |
Environments
Current Workspace, Auto Commit
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
