TIN Aspect (3D Analyst Tools)
Summary
Extracts the directional orientation of input TIN to an output polygon feature class.
Legacy:
This is a deprecated tool that has been superseded by the Surface Aspect tool.
Illustration
TIN Aspect illustration
Usage
  • Aspect is expressed in degrees.
  • Aspect represents the horizontal orientation of a surface and is determined in units of degrees. Each facet of the surface is assigned a code value which represents the cardinal or ordinal direction of its slope, and contiguous areas with the same code are merged into one feature. The default classification scheme is defined as follows:
    Code
    Slope Direction
    Slope Angle Range
    -1
    Flat
    No Slope
    North
    0° – 22.5°
    Northeast
    22.5° – 67.5°
    East
    67.5° – 112.5°
    Southeast
    112.5° – 157.5°
    South
    157.5° – 202.5°
    6
    Southwest
    202.5° – 247.5°
    7
    West
    247.5° – 292.5°
    8
    Northwest
    292.5° – 337.5°
    9
    North
    337.5° – 360°
  • Customized class definitions can be provided through a Class Breaks Table. The table must have two columns where the first indicates the aspect break point in degrees and the second defines its code value. Consider the following example:
    Break
    Aspect_Code
    90.0
    The table can be in any supported format (.dbf, .txt, or geodatabase table). The name of the fields are irrelevant, as the first will always be used for the class breaks and the second for the aspect codes.
Parameters
Label Explanation Data type
Input TIN
The input TIN.
TIN Layer
Output Feature Class
The output feature class.
Feature Class
Class Breaks Table
(Optional)
An input table containing the classification breaks that will be used to classify the output feature class.
Table
Aspect Field
(Optional)
The field containing aspect values.
String
Environments
Current Workspace, Output XY Domain, Output Coordinate System, Extent, Scratch Workspace, XY Resolution, XY Tolerance
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
