TIN Contour (3D Analyst Tools)
Summary
Generates contours from a TIN surface.
Legacy:
This is a deprecated tool that has been superseded by the Surface Contour tool.
Illustration
Usage
Use the interval and base contour options to tailor the extent and resolution of the output feature class.
Use the out contour field data to convert the feature class to 3D.
In certain instances the last valid contour line may not be produced when creating contours using TIN surfaces. This is an algorithmic limitation common to computer contouring software. To ensure that all valid contours are generated, add a very small negative value to the base contour field to slightly shift the data.
Parameters
| Label | Explanation | Data type |
Input TIN |
The surface from which the contours will be interpolated. |
TIN Layer |
Output Feature Class |
The output feature class. |
Feature Class |
Contour Interval |
The interval between the contours. |
Double |
Base Contour (Optional) |
Along with the index interval, the base height is used to determine what contours are produced. The base height is a starting point from which the index interval is either added or subtracted. By default, the base contour is 0.0. |
Double |
Contour Field (Optional) |
The field containing contour values. |
String |
Contour Field Precision (Optional) |
The precision of the contour field. Zero specifies an integer, and the numbers 1–9 indicate how many decimal places the field will contain. By default, the field will be an integer (0). |
Long |
Index Interval (Optional) |
The difference, in Z units, between index contours. The value specified should be evenly divisible by the contour interval. Typically, it's five times greater. Use of this parameter adds an attribute field to the output feature class that's used to differentiate index contours from regular contours. |
Double |
Index Interval Field (Optional) |
The name of the field used to record whether a contour is a regular or an index contour. By default, the value is 'Index'. |
String |
Z Factor (Optional) |
Specifies a factor by which to multiply the surface heights. Used to convert z units to x and y units. |
Double |
Environments
Current Workspace, Output XY Domain, Output Coordinate System, Extent, Scratch Workspace, XY Resolution, XY Tolerance
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
