Surface Contour (3D Analyst Tools)
Summary
Creates contour lines derived from a terrain, TIN, or LAS dataset surface.
Illustration
Usage
The output feature class is 2D and contains an attribute with contour values.
Use the interval and base contour options to tailor the extent and resolution of the output feature class.
Use the out contour field data to convert the feature class to 3D.
In certain instances, the last valid contour line may not be produced when creating contours using TIN surfaces. This is an algorithmic limitation common to computer contouring software. To ensure that all valid contours are generated, add a very small negative value to the Base Contour field to slightly shift the data.
The Z factor parameter only affects results for rasters and TINs, not terrain datasets. When working with terrain datasets you can specify a contour interval that has the z factor built in to it. For example, if you want a one-foot contour interval and your terrain dataset surface is in meters, specify a contour interval of 0.3048. You can also convert the terrain dataset to a raster or TIN using either the Terrain To Raster or Terrain To TIN geoprocessing tools.
Parameters
| Label | Explanation | Data type |
Input Surface |
The TIN, terrain, or LAS dataset surface that will be processed. |
LAS Dataset Layer; Terrain Layer; TIN Layer |
Output Feature Class |
The feature class that will be produced. |
Feature Class |
Contour Interval |
The interval between the contours. |
Double |
Base Contour (Optional) |
Defines the starting Z value from which the contour interval is either added or subtracted to delineate contours. The default value is 0.0. |
Double |
Contour Field (Optional) |
The field that stores the contour value associated with each line in the output feature class. |
String |
Contour Field Precision (Optional) |
The precision of the contour field. Zero specifies an integer, and the numbers 1–9 indicate how many decimal places the field will contain. By default, the field will be an integer (0). |
Long |
Index Interval (Optional) |
Index contours are commonly used as a cartographic aid for assisting in the visualization of contour lines. The index interval is typically five times larger than the contour interval. Use of this parameter adds an integer field defined by the Index Interval Field to the attribute table of the output feature class, where a value of 1 denotes the index contours. |
Double |
Index Interval Field (Optional) |
The name of the field used to identify index contours. This will only be used if the Index Interval is defined. By default, the field name is |
String |
Z Factor (Optional) |
The factor by which z-values will be multiplied. This is typically used to convert z linear units to match x,y linear units. The default is 1, which leaves elevation values unchanged. This parameter is not available if the spatial reference of the input surface has a z-datum with a specified linear unit. |
Double |
Pyramid Level Resolution (Optional) |
The z-tolerance or window-size resolution of the terrain pyramid level that will be used. The default is 0, or full resolution. |
Double |
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations, XY Resolution, XY Tolerance, Output XY Domain, Output CONFIG Keyword, Auto Commit, Minimize memory use during analysis on terrains
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
