TIN Difference (3D Analyst Tools)
Summary
Calculates the volumetric difference between two TIN datasets.
Legacy:
This is a deprecated tool that has been superseded by the Surface Difference tool.
Usage
The horizontal extent of the input TIN surfaces must overlap.
It is best if the horizontal and vertical coordinate systems of the input TINs are the same.
Parameters
| Label | Explanation | Data type |
Input TIN |
The first input TIN. |
TIN Layer |
Input TIN |
The second input TIN. |
TIN Layer |
Output Feature Class |
The output polygon feature class. |
Feature Class |
Environments
Current Workspace, Output XY Domain, Output Coordinate System, Extent, Scratch Workspace, XY Resolution, XY Tolerance
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
