TIN Edge (3D Analyst Tools)
Summary
Creates 3D line features using the triangle edges of a triangulated irregular network (TIN) dataset.
Illustration
TIN Edge illustration
Usage
  • Use the Edge Type parameter to extract a specific type of triangle edge.
  • Output feature contains a field named EdgeType that uses integer values to represent the type of edge that each line represents:
    • 0—A regular edge, or one that was not specifically defined as a hard or soft edge. This edge type is produced by the triangulation of the TIN data points.
    • 1—A soft edge, or one that represents a gradual transition in slope values.
    • 2—A hard edge, or one that represents a more abrupt transition in slope values.
Parameters
Label Explanation Data type
Input TIN
The TIN dataset that will be processed.
TIN Layer
Output Feature Class
The feature class that will be produced.
Feature Class
Edge Type
(Optional)
The triangle edge that will be exported.
  • Data Area—Edges representing the interpolation zone. This is the default.
  • Soft Breaklines—Edges representing gradual breaks in slope.
  • Hard Breaklines—Edges representing distinct breaks in slope.
  • Enforced Edges—Edges that were not introduced by the TIN's triangulation.
  • Regular Edges—Edges that were created by the TIN's triangulation.
  • Excluded Edges—Edges that are excluded from the interpolation zone.
  • All Edges—All edges, included those that were excluded from the interpolation zone.
String
Environments
Current Workspace, Output Coordinate System, Extent, Geographic Transformations, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output Z Domain, Auto Commit, Output XY Domain
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
