An overview of the TIN Dataset toolset
The TIN Dataset toolset contains tools for creating, modifying, and converting triangulated irregular network (TIN) datasets. A TIN can be used to model a surface using measurements from point, line, and polygon features.
Tool
Copy TIN
Creates a copy of a triangulated irregular network (TIN) dataset.
Create TIN
Creates a triangulated irregular network (TIN) dataset.
Decimate TIN Nodes
Creates a triangulated irregular network (TIN) dataset using a subset of nodes from a source TIN.
Delineate TIN Data Area
Redefines the data area, or interpolation zone, of a triangulated irregular network (TIN) based on its triangle edge length.
Edit TIN
Loads data from one or more input features to modify the surface of an existing triangulated irregular network (TIN).
Tools in the TIN Dataset toolset
Conversion Toolset
Tool
LandXML To TIN
This tool imports one or more triangulated irregular network (TIN) surfaces from a LandXML file to output Esri TINs.
TIN Domain
Creates a line or polygon feature class representing the interpolation zone of a triangulated irregular network (TIN) dataset.
TIN Edge
Creates 3D line features using the triangle edges of a triangulated irregular network (TIN) dataset.
TIN Line
Exports breaklines from a triangulated irregular network (TIN) dataset to a 3D line feature class.
TIN Node
Exports the nodes of a triangulated irregular network (TIN) dataset to a point feature class.
TIN Polygon Tag
Creates polygon features using tag values in a triangulated irregular network (TIN) dataset.
TIN To Multipatch
Converts a TIN dataset to a multipatch feature class.
TIN To Raster
Interpolates a raster using z-values from the input TIN.
TIN Triangle
Exports triangle faces from a TIN dataset to polygon features and provides slope, aspect, and optional attributes of hillshade and tag values for each triangle.
