Create TIN (3D Analyst Tools)
Summary
Creates a triangulated irregular network (TIN) dataset.
Illustration
Create TIN tool illustration.
Usage
  • Avoid creating a TIN using a geographic coordinate system, as the Delaunay triangulation rule cannot be effectively enforced when the x,y units are expressed in spherical coordinates.
  • The surface feature type defines how the input features will contribute to the definition of the triangulated surface.
    • Point features can be specified as mass points, which provide data nodes with z-values that are used in the triangulation of the surface.
    • Line features can be specified as mass points and breaklines, which represent locations along a surface with linear discontinuities in slope, such as ridge lines, shore lines, pavement edges, building footprints, and so on.
    • Polygon features can also be specified as mass points and breaklines, along with clip features that define the data area, replace features that define regions with constant z-values (for example, water bodies), and erase features that indicate interior areas where data does not exist.
  • The tool can create a TIN composed of many millions of points given enough memory. However, limiting the number of TIN nodes to less than 6 million will ensure a responsive display performance and overall usability. If a larger TIN surface is needed, consider using a terrain dataset. The terrain dataset offers a multiresolution TIN surface that can support much larger collections of source measurements.
  • Set the Default TIN Storage Version environment to PRE_10.0 if the TIN being created will be used in versions of ArcGIS Desktop earlier than 10.0.
  • Once a TIN dataset is created, you can modify it using the Edit TIN tool to incorporate additional feature-based measurements into the TIN surface. You can also use the Delineate TIN Data Area tool to define which TIN triangles constitute the interpolation zone based on the maximum length of a triangle edge. The TIN surface can also be modified through interactive editing.
Parameters
Label Explanation Data type
Output TIN
The TIN dataset that will be generated.
TIN
Coordinate System
(Optional)
The spatial reference of the output TIN. Set the spatial reference to a projected coordinate system. Geographic coordinate systems are not recommended because Delaunay triangulation cannot be guaranteed when the x,y coordinates are expressed in angular units, which could have an adverse impact on the accuracy of distance-based calculations, such as slope, volume, and line of sight.
Coordinate System
Input Feature Class
(Optional)
The input features and their related properties that define how they will be added to the TIN.
Value table columns:
  • Input Features—The feature whose geometry will be imported to the TIN.
  • Height Field—The source of elevation for the input features. Any numeric field from the input feature's attribute table can be specified, along with Shape.Z for the z-values of 3D features and Shape.M for the m-values stored with the geometry. Choosing the <None> keyword will result in the feature's elevation being interpolated from the surrounding surface.
  • Type—The input feature's role in defining the TIN surface. The available options depend on the geometry of the input features. For line- and polygon-based surface feature types, the hard and soft designations for the surface feature type impact the way the line or polygon boundary is handled when interpolating a raster surface from the TIN dataset when using natural neighbor interpolation. A hard surface feature type represents a border with a sharp discontinuity in elevation, such as the edge of a cliff, a wall, or a curb on the side of the road. A soft surface feature type represents a border where the elevation is more smoothly defined.
    • Mass Points—Elevation measurements will be incorporated as TIN nodes.
    • Hard Line—Breakline features will define linear discontinuities in the TIN.
    • Soft Line—Breakline features will define linear discontinuities in the TIN.
    • Hard Clip—Polygon features will define the data area of the TIN surface.
    • Soft Clip—Polygon features will define the data area of the TIN surface.
    • Hard Erase—Polygon features will define interior voids in the data.
    • Soft Erase—Polygon features will define interior voids in the data.
    • Hard Replace—Polygon features will define areas of constant height.
    • Soft Replace—Polygon features will define areas of constant height.
    • Hard Value Fill—Integer attributes will be assigned to nodes and triangle faces.
    • Soft Value Fill—Integer attributes will be assigned to nodes and triangle faces.
  • Tag Field—A numeric attribute will be assigned to the TIN's data elements using values obtained from an integer field in the input feature's attribute table.
Value Table
Constrained Delaunay
(Optional)
Specifies the triangulation technique that will be used along the breaklines of the TIN.
  • Checked—The TIN will use constrained Delaunay triangulation, which will add each segment as a single edge. Delaunay triangulation rules are honored everywhere except along breaklines, which will not be densified.
  • Unchecked—The TIN will use Delaunay conforming triangulation, which may densify each segment of the breaklines to produce multiple triangle edges. This is the default.
Boolean
Environments
Current Workspace, Output Coordinate System, Extent, Geographic Transformations, Default TIN Storage Version
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
