An overview of the 3D Analyst toolbox
Available with 3D Analyst license.
The 3D Analyst toolbox provides a collection of geoprocessing tools that enable a wide variety of analytical, data management, and data conversion operations on surface models and three-dimensional vector data.
3D Analyst tools allow you to create and analyze surface data represented in raster, terrain, triangulated irregular network (TIN), and LAS dataset formats. 3D data can be converted from a variety of formats, including COLLADA, lidar, SketchUp, OpenFlight, and many other data types. Analysis of geometric relationships and feature properties, interpolation of raster and various TIN models, and analysis of surface properties are some of the numerous functions provided by 3D Analyst tools.
Learn about data in 3D
Learn about elevation surfaces
Toolset
3D Features
Evaluate geometric properties and spatial relationships between 3D features.
3D Intersections
Analyze the overlaps and intersections of 3D volumes, features, and surfaces to derive new insights about 3D data.
3D Proximity
Perform distance-based evaluations of 3D points, point clouds, lines, and multipatch features.
Area and Volume
Measure surface area and volume between surfaces and generate volumetric representations of 3D data.
Feature Extraction
Extract 3D buildings, powerlines, rail tracks, and other features from point clouds and surfaces and refine building footprints derived from imagery and lidar.
Point Cloud
Classify, manage, and train deep learning models for LAS format point clouds.
Raster
Interpolate raster surfaces from point measurements, perform custom analysis on raster cell values using math operators, and generate derivatives to obtain helpful insights from raster datasets.
Statistics
Aggregate 3D statistics from features, point clouds, raster, and triangulated surfaces.
Terrain Dataset
Create, manage, and convert terrain datasets.
TIN Dataset
Create, modify, and convert TIN datasets.
Triangulated Surface
Create slope, aspect. and contour derivatives from TIN, terrain, and LAS datasets, and detect outlier measurements.
Visibility
Perform visibility analysis operations on 3D data and elevation surfaces.
Overview of toolsets in the 3D Analyst toolbox
