3D Analyst toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
ASCII 3D To Feature Class
Version
1.0
Ported from ArcMap 10.3
Add Feature Class To Terrain
Version
1.0
Add Surface Information
Version
1.0
Add Terrain Pyramid Level
Version
1.0
Add Z Information
Version
3.0
Required Extension changed from 3D Analyst to None
1.0
Append Terrain Points
Version
1.0
Aspect
Version
3.7
Parameter z_unit has new option added: FOOT_US
3.6
New environments added:
  • gpuID
  • processor_type
An input raster with rectangular cells will be processed so that the output raster cells will be square with sides equal to the average of the rectangular length and width.
3.1
New parameter added: analysis_target_device
2.7
New parameter added: project_geodesic_azimuths
2.3
New environment added: cellSizeProjectionMethod
2.0
2 new parameters added:
  • method
  • z_unit
The method parameter allows you choose between the traditional planar method for performing the calculations, and the new geodesic method.
When using the geodesic option:
  • A new z_unit parameter is available, which allows you to specify the linear unit of the vertical z-values if it is not already defined in the coordinate system of the input.
  • If a suitable GPU device is available on your system, greater performance will come as a result of the calculations being GPU accelerated.
The behavior for how NoData cells and boundary cells are handled was changed. At least seven of the eight cells neighboring the processing cell must have a value, otherwise the output will be NoData. Cells in the outermost rows and columns of the output raster will be NoData.
1.0
Buffer 3D
Version
1.0
Build Terrain
Version
1.0
Calculate Missing Z Values
Version
3.5
New at this version
Change LAS Class Codes
Version
2.8
New parameter added: update_pyramid
2.4
Default value for parameter compute_stats changed from False to True
1.2
3 new parameters added:
  • boundary
  • process_entire_files
  • extent
1.0
Change Terrain Reference Scale
Version
1.0
Change Terrain Resolution Bounds
Version
1.0
Classify LAS Building
Version
2.8
2.5
6 new parameters added:
  • classification_option
  • classify_below_roof_point
  • below_roof_point_code
  • above_roof_point_code
  • max_above_roof_height
  • classify_above_roof_point
Parameter min_height changed from Optional to Required
Parameter min_area changed from Optional to Required
2.4
  • reuse_building
  • photogrammetric_data
2.1
Environment added: Parallel Processing Factor
New parameter added: point_spacing
1.3
New at this version
Classify LAS By Height
Version
3.2
New parameter added: in_surface
Parameter ground_source had new option added: SURFACE
2.8
2.4
1.2
New parameter added: boundary
1.0
New at this version
Classify LAS Ground
Version
3.5
5 new parameters added:
  • window_size
  • classification_type
  • classify_key_points
  • window_size_method
  • z_tolerance
Parameter method had new option added: CLASSIFY_MODEL_KEY_POINTS
3.4
Parameter method had new option added: RECOVER_RIDGES
3.2
  • classify_high_noise
  • classify_low_noise
  • minimum_height_above_ground
  • minimum_depth_below_ground
  • preserve_low_noise
  • preserve_high_noise
3.1
New parameter added: algorithm
2.8
2.4
1.2
New at this version
Classify LAS Noise
Version
2.8
2.4
2.0
New at this version
Classify LAS Overlap
Version
2.8
2.4
2.0
New at this version
Classify Point Cloud Using Trained Model
Version
3.0
  • excluded_class_codes
  • reference_height
  • batch_size
2.8
New at this version
Colorize LAS
Version
3.7
New parameter added: relative_paths
2.4
2.1
New at this version
Construct Sight Lines
Version
2.3
New parameter added: sampling_method
1.0
Contour
Version
3.6
2.4
Multi-core support added. Use the Parallel Processing Factor environment to control the number of cores used by the tool.
2.3
2.2
  • contour_type
  • max_vertices_per_feature
1.0
Contour List
Version
3.7
New parameter added: contour_type
2.4
2.3
1.0
Contour with Barriers
Version
1.0
Copy TIN
Version
1.0
Create Terrain
Version
2.9
New parameter added: triangulation_method
1.0
Create Terrain From BIM
Version
3.7
New at this version
Create TIN
Version
1.0
Curvature
Version
2.3
1.0
Cut Fill
Version
2.3
1.0
Decimate TIN Nodes
Version
1.0
Delete Terrain Points
Version
1.0
Delineate TIN Data Area
Version
1.0
Detect Objects From Point Cloud Using Trained Model
Version
3.2
New at this version
Difference 3D
Version
1.0
Divide
Version
2.3
1.0
Edit TIN
Version
1.0
Enclose Multipatch
Version
1.3
Environments added:
  • XY Resolution
  • Z Resolution
1.0
Enforce River Monotonicity
Version
3.0
New at this version
Evaluate Point Cloud Classification Model
Version
3.0
  • reference_height
Parameter in_trained_model has new data type: Value Table
Parameter in_trained_model had 2 data types removed:
  • File
  • String
2.9
New at this version
Extract LAS
Version
2.8
Parameter in_las_dataset has 2 new data types:
  • Scene Layer
  • File
2.4
New parameter added: compression
1.1
New at this version
Extract LOD2 Buildings
Version
3.6
Parameter in_height_source has new data type: LAS Dataset Layer
3.5
New at this version
Extract Mesh Features Using Point Cloud
Version
3.5
New at this version
Extract Multipatch From Mesh
Version
2.6
New at this version
Extract Objects From Point Cloud
Version
3.6
  • max_height
  • min_height
3.3
  • vertical_scale_factor
  • alpha_radius
  • alpha_calculation
Parameter geometry_type had new option added: CONCAVE_HULL_3D
3.2
New at this version
Extract Power Lines From Point Cloud
Version
3.2
Parameter in_point_cloud has 2 new data types:
  • File
  • Scene Layer
3.1
New parameter added: min_line_length
3.0
New parameter added: eliminate_wind
2.7
New at this version
Extract Rails From Point Cloud
Version
3.4
New at this version
Extrude Between
Version
1.0
Feature Class Z To ASCII
Version
1.0
Feature To 3D By Attribute
Version
1.0
Features From CityEngine Rules
Version
1.1
  • in_include_reports
  • out_lines
  • out_points
  • in_existing_fields
  • in_leaf_shapes
  • out_multipoints
1.0
Fence Diagram
Version
2.1
New at this version
Float
Version
2.3
1.0
Generate Clearance Surface
Version
3.1
New at this version
Generate Points Along 3D Lines
Version
3.5
New at this version
Geodesic Viewshed
Version
3.6
  • gpuID
  • processor_type
3.1
2.8
Tool label changed from Viewshed 2 to Geodesic Viewshed.
2.3
1.1
New at this version
Ported from ArcMap 10.3.1
HillShade
Version
2.3
1.0
IDW
Version
2.3
1.0
Import 3D Files
Version
2.3
2.1
Parameter file_suffix had new option added: OBJ
1.2
Parameter symbol_field changed from Required to Optional
1.0
Inside 3D
Version
1.0
Int
Version
2.3
1.0
Interpolate Polygon To Multipatch
Version
1.3
Environments added:
  • XY Resolution
  • Z Resolution
1.0
Interpolate Shape
Version
3.7
New parameter added: interpolate_m_value
2.7
Parameter in_surface has new data type: Image Service
2.2
New parameter added: preserve_features
Parameter method had new option added: NEAREST
1.0
Intersect 3D
Version
1.0
Intersect 3D Line With Multipatch
Version
1.0
Intersect 3D Line With Surface
Version
1.0
Intersect 3D Lines
Version
2.6
New at this version
Intervisibility
Version
2.7
Parameter obstructions has new data type: File
2.6
Parameter obstructions has new data type: Scene Layer
1.0
Is Closed 3D
Version
1.0
Kriging
Version
2.3
1.0
LAS Building Multipatch
Version
3.3
  • min_height_field
  • max_height_field
3.0
New parameter added: sampling_resolution
1.4
New at this version
LAS Height Metrics
Version
2.4
New parameter added: raster_format
2.1
New at this version
LAS To Multipoint
Version
3.2
Parameter input has new data type: LAS Dataset Layer
1.0
LandXML To TIN
Version
1.0
LAS Dataset To TIN
Version
2.2
New parameter added: clip_to_extent
1.0
LAS Point Statistics By Area
Version
1.0
New at this version
Layer 3D To Feature Class
Version
1.1
Line Of Sight
Version
3.4
New parameter added: output_graphing_attributes
2.7
Parameter in_surface has 2 new data types:
  • File
  • Scene Layer
1.0
Locate LAS Points By Proximity
Version
2.8
2.4
1.0
New at this version
Locate Outliers
Version
1.0
Lookup
Version
2.3
1.0
Minimum Bounding Volume
Version
1.1
New at this version
Minus
Version
2.3
1.0
Multipatch Footprint
Version
1.3
Environments removed:
  • Output XY Domain
  • Z Resolution
  • Output Z Domain
  • Z Tolerance
New parameter added: group_field
1.0
Natural Neighbor
Version
2.3
1.0
Near 3D
Version
1.0
Observer Points
Version
2.3
1.0
Plus
Version
3.6
2.3
1.0
Point File Information
Version
3.2
Parameter input has 2 new data types:
  • Folder
  • LAS Dataset Layer
2.4
1.0
Polygon Volume
Version
3.1
4 new parameters added:
  • out_volume_above_field
  • out_volume_below_field
  • surface_area_above_field
  • surface_area_below_field
Parameter reference_plane had new option added: BOTH
1.0
Prepare Point Cloud Object Detection Training Data
Version
3.2
New at this version
Prepare Point Cloud Training Data
Version
3.0
  • reference_height
2.8
New at this version
Raster Domain
Version
1.0
Raster To TIN
Version
1.0
Raster To Multipoint
Version
1.0
Reclass by ASCII File
Version
2.3
1.0
Reclass by Table
Version
2.3
1.0
Reclassify
Version
3.6
2.3
1.0
Regularize Adjacent Building Footprint
Version
2.1
New at this version
Regularize Building Footprint
Version
2.9
  • alignment_feature
  • tolerance_type
  • alignment_tolerance
2.5
Parameter method had new option added: ANY_ANGLES_WITH_BIAS
2.0
1.1
New at this version
Remove Feature Class From Terrain
Version
1.0
Remove Terrain Pyramid Level
Version
1.0
Replace Terrain Points
Version
1.0
Set LAS Class Codes Using Features
Version
2.8
2.4
1.0
Set LAS Class Codes Using Raster
Version
2.8
2.5
New at this version
Simplify 3D Line
Version
2.5
New at this version
Skyline
Version
3.4
New parameter added: vertical_offset
3.1
New parameter added: apply_max_radius_to_features
1.0
Skyline Barrier
Version
1.0
Skyline Graph
Version
2.9
New parameter added: out_image_file
1.0
Slice
Version
3.6
2.9
  • nodata_to_value
  • class_interval_size
Parameter slice_type has 4 new options:
  • STANDARD_DEVIATION_MEAN_CENTERED
  • GEOMETRIC_INTERVAL
  • DEFINED_INTERVAL
  • STANDARD_DEVIATION_MEAN_BREAK
Parameter number_zones changed from Required to Optional
2.3
1.0
Slope
Version
3.7
3.6
  • gpuID
  • processor_type
3.1
2.3
2.0
  • method
  • z_unit
1.0
Spline
Version
2.3
1.0
Spline with Barriers
Version
2.0
Ported from ArcMap 10.5
Stack Profile
Version
3.7
2 parameters added:
  • multipatch_rep
  • out_legacy_table
Parameter out_graph has new data type: String
Parameter out_graph has removed data type: Graph
Direction for parameter out_graph changed from Output to Input
1.0
Sun Shadow Frequency
Version
2.7
Parameter time_zone had new option added: Yukon_Standard_Time
2.5
Parameter time_zone had new option added: Qyzylorda_Standard_Time
2.2
New at this version
Sun Shadow Volume
Version
2.7
2.5
2.2
Parameter time_zone has 2 new options:
  • Sudan_Standard_Time
  • Sao_Tome_Standard_Time
1.0
Surface Aspect
Version
1.0
Surface Contour
Version
1.0
Surface Difference
Version
2.1
  • reference_method
  • boundary
  • method
  • extent
Parameter in_reference_surface has new data type: LAS Dataset Layer
Parameter in_surface has new data type: LAS Dataset Layer
1.0
Surface Parameters
Version
3.7
3.6
3.1
New parameter added: in_analysis_mask
2.9
Parameter parameter_type had four new options:
  • CONTOUR_CURVATURE
  • CONTOUR_GEODESIC_TORSION
  • GAUSSIAN_CURVATURE
  • CASORATI_CURVATURE
2.7
New at this version
Surface Slope
Version
1.0
Surface Volume
Version
1.0
Terrain To Points
Version
1.0
Terrain To Raster
Version
1.0
Terrain To TIN
Version
1.0
Thin LAS
Version
2.4
2.1
New at this version
Tile LAS
Version
2.4
2.2
New parameter added: out_folder
1.3
New at this version
Times
Version
2.3
1.0
TIN Domain
Version
1.0
TIN Edge
Version
1.0
TIN Line
Version
1.0
TIN Node
Version
1.0
TIN Polygon Tag
Version
1.0
TIN To Multipatch
Version
3.7
New at this version
Version
1.0
Version
1.0
Version
2.3
1.0
Version
1.0
Version
3.5
Parameter architecture had new option added: POINT_TRANSFORMER_V3
3.4
New parameter added: loss_function
3.2
Parameter architecture had new option added: MMDETECTION3D_SECOND
3.1
New parameter added: architecture
3.0
Parameter attributes had new option added: RELATIVE_HEIGHT
2.9
  • learning_rate_strategy
  • out_epoch_stats
2.8
New at this version
Version
3.5
3.2
New at this version
Version
2.3
1.0
Version
1.0
Version
1.4
New at this version
Version
2.3
1.0
Version
2.3
1.0
