Observer Points (3D Analyst Tools)
Summary
Identifies which observer points are visible from each raster surface location.
The Geodesic Viewshed tool provides enhanced functionality or performance.
Learn more about how Observer Points works
Illustration
Observer points illustration
Observer points output displayed on a hillshaded elevation surface
Usage
  • Determining observer points is a computer-intensive process. The processing time is dependent on the resolution. For preliminary studies, you can use a coarser cell size to reduce the number of cells in the input. Use the full-resolution raster when the final results are ready to be generated.
  • If the input raster contains undesirable noise caused by sampling errors, and you have the ArcGIS Spatial Analyst extension, you can smooth the raster with a low-pass filter, such as the Mean option of the Focal Statistics tool, before running this tool.
  • The visibility of each cell center is determined by comparing the altitude angle to the cell center with the altitude angle to the local horizon. The local horizon is computed by considering the intervening terrain between the point of observation and the current cell center. If the point lies above the local horizon, it is considered visible.
  • An optional above ground level (AGL) output raster is provided by the tool. Each cell on the AGL output raster records the minimum height that needs to be added to that cell to make it visible by at least one observer.
    When the input observer features contain multiple observers, the output value is the minimum of the AGL values from all of the individual observers.
  • When the input raster needs to be resampled, the bilinear technique will be used. An example of when an input raster may be resampled is when the output coordinate system, extent, or cell size is different from that of the input.
Parameters
Label Explanation Data type
Input raster
The input surface raster.
Raster Layer
Input point observer features
The point feature class that identifies the observer locations.
The maximum number of points allowed is 16.
Feature Layer
Output raster
The output raster.
The output identifies exactly which observer points are visible from each raster surface location.
Raster Dataset
Z factor
(Optional)
The number of ground x,y units in one surface z-unit.
The z-factor adjusts the units of measure for the z-units when they are different from the x,y units of the input surface. The z-values of the input surface are multiplied by the z-factor when calculating the final output surface.
If the x,y units and z-units are in the same units of measure, the z-factor is 1. This is the default.
If the x,y units and z-units are in different units of measure, the z-factor must be set to the appropriate factor or the results will be incorrect. For example, if the z-units are feet and the x,y units are meters, use a z-factor of 0.3048 to convert the z-units from feet to meters (1 foot = 0.3048 meter).
Double
Use earth curvature corrections
(Optional)
Specifies whether correction for the earth's curvature will be applied.
  • Checked—Curvature correction will be applied.
  • Unchecked—No curvature correction will be applied. This is the default.
Boolean
Refractivity coefficient
(Optional)
The coefficient of the refraction of visible light in air.
The default value is 0.13.
Double
Output above ground level raster
(Optional)
The output above ground level (AGL) raster.
The AGL result is a raster where each cell value is the minimum height that must be added to an otherwise nonvisible cell to make it visible by at least one observer.
Cells that were already visible will have a value of 0 in this output raster.
Raster Dataset
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires 3D Analyst or Spatial Analyst
  • Standard: Requires 3D Analyst or Spatial Analyst
  • Advanced: Requires 3D Analyst or Spatial Analyst
