An overview of the Visibility toolset
Available with 3D Analyst license.
The Visibility toolset features tools for performing various forms of visibility analysis, ranging from constructing shadow models and sight lines to generation of viewsheds and skylines.
License:
Certain Visibility tools are also available with a ArcGIS Spatial Analyst extension license. These tools are: Observer Points, Viewshed, Geodesic Viewshed, and Visibility.
Tool
Construct Sight Lines
Creates line features that represent sight lines from one or more observer points to features in a target feature class.
Geodesic Viewshed
Determines the raster surface locations visible to a set of observer features using geodesic methods.
Intervisibility
Determines the visibility of sight lines using potential obstructions defined by any combination of 3D features and surfaces.
Line Of Sight
Determines the visibility of sight lines over obstructions consisting of a surface and an optional multipatch dataset.
Observer Points
Identifies which observer points are visible from each raster surface location.
Skyline
Generates a line or multipatch feature class containing the results from a skyline or silhouette analysis.
Skyline Barrier
Generates a multipatch feature class representing a skyline barrier or shadow volume.
Skyline Graph
Calculates the sky visibility ratio and generates an optional table and a polar graph.
Sun Shadow Frequency
Calculates the number of times a fixed position on a surface has its direct sight line to the sun obstructed by multipatch features.
Sun Shadow Volume
Creates closed volumes that model shadows cast by each feature using sunlight for a given date and time.
Viewshed
Determines the raster surface locations visible to a set of observer features.
Visibility
Determines the raster surface locations visible to a set of observer features, or identifies which observer points are visible from each raster surface location.
Overview of tools in the Visibility toolset
