Layer 3D To Feature Class (3D Analyst Tools)
Summary
Exports feature layers with 3D display properties to 3D lines or multipatch features.
Usage
  • Procedural rules and attribute-driven symbols are supported and will be preserved in the resulting multipatch.
  • Feature layers with symbology that has the following properties will be exported to a multipatch:
    • Extrusion or base height settings.
    • Character marker symbols with depth.
    • 3D model marker symbols whose size is denoted in real-world linear units such as feet, inches, meters, or centimeters. Color (including texture color) is the only material property from 3D model marker symbology that is honored.
    • Picture marker symbols can only be converted to multipatches if they display in a fixed spatial extent. That is, they must be in real-world size units, and they cannot be billboarded.
    • All line symbology.
    • All polygon symbology. If a polygon layer is provided without any 3D display properties, it will be exported as a multipatch that resembles the polygon.
  • This tool does not support features symbolized with any of the following properties:
    • Shape marker symbols that come from a file on disk.
    • Rasterized layers that are draped on the scene's surface.
    • Shape marker symbols that are sourced from a font but do not have a depth property.
    • 3D marker symbols whose size is not specified in real-world linear units such as feet, inches, meters or centimeters.
    • Any marker symbols that are billboarded. The position of these 2D symbols are dynamically oriented to face the camera position in a 3D scene, so they have no fixed orientation that can be used for exporting.
  • Environment settings for x,y,z tolerance and resolution are only supported when the output is a line feature.
  • When using Google's Photorealistic 3D Tiles (Google mesh) as a basemap and the input layer's elevation property is set to On the ground the output will not have the elevation or z-values calculated from the Google mesh. To have updated elevation or z-values in the output use a basemap with Terrain 3D.
Parameters
Label Explanation Data type
Input Feature Layer
The input feature layer with 3D display properties defined.
Feature Layer
Output Feature Class
The output feature class with 3D features. Extruded points will be exported as 3D lines. Points with 3D symbols, extruded lines, and polygons will be exported as multipatch features.
Feature Class
Grouping Field
(Optional)
The input feature's text field that will be used to merge multiple input features into the same output feature. The resulting output's remaining attributes will be inherited from one of the input records.
Field
Disable Color and Texture
(Optional)
Specifies whether color and texture properties will be maintained when exporting a 3D layer to a multipatch feature class.
  • Checked—Colors and textures will not be stored as part of the multipatch definition.
  • Unchecked—Colors and textures will be preserved with the multipatch. This is the default.
Boolean
Environments
Current Workspace, Output XY Domain, Output Z Domain, Output Coordinate System, Geographic Transformations, Extent, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output CONFIG Keyword, Auto Commit, Transfer Geodatabase Field Properties
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
