Transfer Geodatabase Field Properties (Environment setting)
Tools that honor the Transfer Geodatabase Field Properties environment will transfer domains, subtypes, attribute rules, field groups, and contingent values from the input dataset's fields to the output dataset's fields.
Usage notes
  • Transferring domains, subtypes, attribute rules, field groups, and contingent values to the output of the geoprocessing operation will take additional time (resulting in slower performance). Only use this environment setting if domains, subtypes, attribute rules, field groups, and contingent values are specifically needed in the output.
Dialog syntax
  • Checked—Geodatabase field properties are transferred to the output.
  • Unchecked—Geodatabase field properties are not transferred to the output. This is the default.
Python syntax
arcpy.env.transferGDBAttributeProperties = transfer_attributes
Name Explanation
transfer_attributes
  • True—Geodatabase field properties are transferred to the output.
  • False—Geodatabase field properties are not transferred to the output. This is the default.
Scripting syntax
import arcpy
# Set the transferGDBAttributeProperties environment to True
arcpy.env.transferGDBAttributeProperties = True
