TIN Polygon Tag (3D Analyst Tools)
Summary
Creates polygon features using tag values in a triangulated irregular network (TIN) dataset.
Illustration
Usage
Tag values can be assigned using an integer field in a polygon feature class by loading the polygon into the TIN as a valuefill surface type.
Triangles that do not have a tag explicitly defined are assigned the default value of 0.
All contiguous triangles with an identical tag value will be stored in a single polygon feature.
The tag value will be denoted as an attribute in the output feature class.
Parameters
| Label | Explanation | Data type |
Input TIN |
The TIN dataset that will be processed. |
TIN Layer |
Output Feature Class |
The feature class that will be produced. |
Feature Class |
Tag Value Field (Optional) |
The name of the field storing the tag attribute in the output feature class. The default field name is Tag_Value. |
String |
Environments
Current Workspace, Output Coordinate System, Extent, Geographic Transformations, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output Z Domain, Output CONFIG Keyword, Auto Commit, Output XY Domain
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
