Find Nearby Locations (Business Analyst Tools)
Summary
Identifies locations closest to the input features based on a selected distance type. The number of points in the output is defined by limiting the count or percentage of location points to return or by limiting the distance from the input points.
Usage
  • The Input Features parameter value must be a point feature class. The input features are the sites you are analyzing, such as stores or facilities.
  • The Location Points parameter value contains the origin points, such as store locations.
  • The Location Points parameter value must be a point feature class. The location points are all nearby locations that will be used in the tool calculations.
  • The Output Feature Class parameter will contain all attributes from the Input Features and Location Points parameters, as well as calculated fields containing distance and direction values.
  • The Interpret a Find Nearby Locations report is a PDF document you can use to understand the various sections and elements of the Find Nearby Locations report.
Parameters
Label Explanation Data type
Input Features
The layer containing points to be measured in relation to the Location Points layer. This layer contains the origin points, such as store locations.
Feature Layer
ID Field
A field containing unique identifiers for each input feature.
Field
Location Points
The layer containing points to be measured for distance and direction in relation to the Input Features parameter value. This layer contains the nearby points, such as customer locations.
Feature Layer
The output location point features.
Feature Class
Distance Type
(Optional)
The calculated distance based on the method of travel. Straight Line is the default value.
String
Distance Units
(Optional)
The measurement units, in distance or time, that will be used when calculating nearby locations.
String
Distance Limit
(Optional)
The analysis extent measured in distance or time.
Double
Number of Locations Limit
The numeric limit of the Location Points value.
Long
Percentage of Locations Limit
The closest points, as a percentage of the points of the Location Points value.
Double
Create Report
(Optional)
Specifies whether an output report will be created.
  • Checked—A report will be created.
  • Unchecked—A report will not be created. This is the default.
Boolean
Report Title
(Optional)
The title of the output report.
String
Output Report Folder
(Optional)
The directory that will contain the output report.
Folder
Report Output Formats
(Optional)
The output report formats. The default value is PDF. Additional available formats are XLSX, S.XLSX, HTML, S.XML, ZIP, CVS, and PAGX.
String
Report Fields
(Optional)
The additional fields that will be added to the report.
Field
Travel Direction
(Optional)
Specifies whether travel times or distances will be measured from location points to input features or from input features to location points.
  • Toward Input Features—The direction of travel will be from location points to input features. This is the default.
  • Away from Input Features—The direction of travel will be from input features to location points.
String
Time of Day
(Optional)
The time at which travel will begin.
Date
Time Zone
(Optional)
Specifies the time zone that will be used for the Time of Day parameter.
  • UTC—Coordinated universal time (UTC) will be used. Choose this option if you want the best location for a specific time, such as now, but aren't certain of the time zone in which the Location Points value will be located.
  • Local time at locations—The time zone in which the Location Points value is located will be used. This is the default.
String
Search Tolerance
(Optional)
The maximum distance that input points can be from the network. Points located beyond the search tolerance will be excluded from processing.
Linear Unit
Location Name
(Optional)
A field from the input Location Points parameter. This field contains the name or ID for each input point used in the Find Nearby Locations report.
Field
Derived output
Output Report
The output report file.
File
Environments
Current Workspace, Data Source, Network Source
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
