Generate Huff Equal Probability Trade Areas (Business Analyst Tools)
Summary
Analyzes and visualizes dominance areas around stores or facilities. The tool requires a negative distance exponent (typically between -1 and -3) and a positive attractiveness exponent.
Usage
The Input Features parameter must be point features.
Weights can be calculated based on the results of a Huff Model Calibration file (
.huffmodel). This file contains analysis exponents calculated based on user data.The Distance Exponent parameter determines how much of a factor distance is relative to each store. The parameter is a negative number because attractiveness decreases when distance increases.
Parameter values between -0.4 to -0.9 are best used for luxury goods or destination-specific locations—for example, furniture, large appliances, or car dealerships. Consumers are willing to tolerate longer travel times or distances to compare options and find the best fit.
Parameter values between -1.5 to -2.5 produce small, localized trade areas. Convenience stores and fast food outlets have distance exponents in this range.
A store with the weakest attractiveness will show the smallest dominance area.
Parameters
| Label | Explanation | Data type |
Input Features |
The input feature class containing center points for the trade areas. In most cases, this will be a store or facility layer. |
Feature Layer |
ID Field |
The unique ID field in the store or facility layer. |
Field |
Output Feature Class |
The feature class that will contain the probability trade area features. |
Feature Class |
Use Existing Huff Model Calibration (Optional) |
Specifies the method that will be used to define the distance exponent and attractiveness variables.
String |
Huff Model Calibration File (Optional) |
The location of a Huff Model Calibration file ( |
File |
Distance Exponent (Optional) |
The value that determines how much of a factor distance (travel) affects consumer behavior. The default value is -1.5. |
Double |
Attractiveness Variables (Optional) |
The attribute fields that indicate the attractiveness of each competitor. In many cases, the size of the facility is used as a substitute for attractiveness and will be a multivalue table. Value table columns:
Value Table |
Environments
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
