Generate Threshold Drive Times (Business Analyst Tools)
Summary
Creates a feature class of network distance trade areas that expand around point features until criteria is reached.
Usage
  • The size of output polygons is determined by the Threshold Values parameter value provided for a selected Threshold Variable parameter value from the Business Analyst dataset.
  • The Threshold Variable parameter accepts only variables of Count type. Median, Average, Percent, or Index cannot be used.
  • Multiple threshold drive time polygons can be created around each input by typing individual values into separate threshold value text boxes.
  • The ID Field parameter uniquely identifies the point location around which threshold drive time polygons will be created.
Parameters
Label Explanation Data type
Input Features
The input point feature layer.
Feature Layer
Output Feature Class
The output feature class containing the drive time polygons.
Feature Class
Threshold Variable
The selected Business Analyst dataset variable to which the threshold value will be applied.
Threshold variables must be numeric. No other statistic type is supported.
String
Threshold Values
The threshold variable value that will determine the size of the output rings. The rings will expand until they contain the threshold value of the selected variable.
Double
Distance Type
The method of travel that will be used to create the output polygons.
String
Distance Units
(Optional)
The distance units that will be used with the threshold values.
String
ID Field
(Optional)
The ID that uniquely identifies each input point and is included in the output as an attribute.
Field
Travel Direction
(Optional)
Specifies the direction of travel toward or away from stores.
  • Toward stores—The direction of travel will be toward stores. This is the default.
  • Away from stores—The direction of travel will be away from stores.
String
Time of Day
(Optional)
The time and date that will be used when calculating distance.
Date
Time Zone
(Optional)
Specifies the time zone that will be used for the Time of Day parameter.
  • Time Zone at Location—The time zone in which the territories are located will be used. This is the default.
  • UTC—Coordinated universal time (UTC) will be used.
String
Search Tolerance
(Optional)
The maximum distance that input points can be from the network.
The default value is 5,000 meters.
Linear Unit
Polygon Detail
(Optional)
Specifies the level of detail that will be used for the output drive time polygons.
  • Standard—Polygons with a standard level of detail will be created. This is the default.
  • Generalized—Generalized polygons will be created using the hierarchy present in the network data source to produce results quickly.
  • High—Polygons with a high level of detail will be created for applications in which precise results are important.
String
Iterations Limit
(Optional)
Restricts the number of drive times that can be used to find the optimal threshold limit.
Long
Minimum Step
(Optional)
The minimum distance between one threshold area candidate and the next as the model approaches the threshold value to prevent infinite iterations.
Double
Threshold Percent Difference
(Optional)
The maximum percentage difference between the target value and threshold value that will be used when determining the threshold drive time, for example, 5 percent. The default value is 5.
Double
Input Method
(Optional)
Specifies the type of value that will be used for each drive time.
  • Values—A constant value will be used (all trade areas will be the same size). This is the default.
  • Expression—The values from a field or an expression will be used (trade areas can be different sizes).
String
Expression
(Optional)
A fields-based expression that will be used to calculate drive time.
SQL Expression
Environments
Current Workspace, Data Source, Network Source, Geographic Transformations
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
