Cul-De-Sac Masks (Cartography Tools)
Summary
Creates a feature class of polygon masks from a symbolized input line layer.
Usage
  • This tool only creates masks at the unconnected ends of lines (also called culs-de-sac). A line end is considered connected if it shares its endpoint with the endpoint of another line. This tool only accepts line layers as input.
  • This tool is designed to provide line end masks in cases in which lines have been symbolized using a rounded end cap to smooth the transition of line connections. Rather than having lines end with a rounded end cap, the end of the line can be masked using the polygon feature class created with this tool.
  • Typically, margins are greater than 0. A margin size of 0 creates masks that represent the exact shape of the symbolized features.
  • If the input line layer contains multipart line geometries, cul-de-sac masks are created for all unconnected line ends, including the ends of parts within multipart lines.
  • When creating masks, it is important to know that adding masks to maps adds complexity that will slow map drawing and affect map printing and exporting. Generally, there are three things to consider when creating masks for a map: the number of masks, the complexity of the masks, and whether the masks will be used to mask polygon features filled with marker or line symbols. An increase in the number of masks, having more complex masks, and masking against marker or polygon fill symbols will result in slower drawing on your screen. In addition, printing and exporting performance can be poor and even fail to produce valid output. This is because of the large amount of processing required to print and export maps with masks, and because of known limitations in how graphic file formats store map export results that have many complicated masks.
  • Margin values are specified in either page units or map units. Most of the time, you will specify your margin distance value in page units.
    Margin value units are interpreted differently depending on the units you choose. If you choose points, inches, millimeters, or centimeters, masks are created using the margin distance as calculated in page space (you can think of the margin as a distance measured on the paper). The reference scale parameter value is taken into account in this calculation.
    If you choose any other units for your margin, masks are created using the margin distance as calculated in map space (you can think of the margin as a real-world distance measure on the earth). Also, in this case, the reference scale parameter value is not used as part of the calculation.
Parameters
Label Explanation Data type
Input Layer
The input line layer from which the masks will be created.
Layer
Output Feature Class
The feature class that will contain the mask features.
Feature Class
Reference Scale
The reference scale used for calculating the masking geometry when masks are specified in page units. This is typically the reference scale of the map.
Double
Calculation coordinate system
The spatial reference of the map in which the masking polygons will be created. This is not the spatial reference that will be assigned to the output feature class. It is the spatial reference of the map in which the masking polygons will be used, since the position of symbology may change when features are projected.
Spatial Reference
Margin
The space in page units surrounding the symbolized input features used to create the mask polygons. Typically, masking polygons are created with a small margin around the symbol to improve visual appearance. Margin values are specified in either page units or map units. Most of the time, you will specify your margin distance value in page units.
The margin cannot be negative.
Linear Unit
Transfer Attributes
(Optional)
Specifies the attributes that will be transferred from the input features to the output features.
  • Only feature IDs—Only the FID field from the input features will be transferred to the output features. This is the default.
  • All attributes except feature IDs—All the attributes except the FID from the input features will be transferred to the output features.
  • All attributes—All the attributes from the input features will be transferred to the output features.
String
Environments
Cartographic Coordinate System
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
