Add CAD Fields (Conversion Tools)
Summary
Adds several reserved CAD fields in one step. Fields created by this tool are used by the Export To CAD tool to generate CAD entities with specific properties. After executing this tool, you must calculate or type the appropriate field values.
Usage
  • All input feature classes and/or feature layers are valid inputs to this tool.
  • You can add fields to a table other than a feature class and join the tables using a field that exists in both tables. Using a lookup table can be an efficient way to standardize and reuse common CAD property values.
  • If the input is a table view or a feature layer with a joined table, the fields are only added to the base table (not to the joined table).
Parameters
Label Explanation Data type
Input Table
Input table, feature class, or shapefile that will have the CAD-specific fields added to it
Table View
Entity Properties
Adds the list of CAD-specific Entity property fields to the input table
  • Checked—Adds the list of CAD-specific Entity property fields to the input table
  • Unchecked—Does not add the list of CAD-specific Entity property fields to the input table
Boolean
Layer Properties
(Optional)
Adds the list of CAD-specific Layer property fields to the input table
  • Checked—Adds the list of CAD-specific Layer property fields to the input table
  • Unchecked—Does not add the list of CAD-specific Layer property fields to the input table
Boolean
Text Properties
(Optional)
Adds the list of CAD-specific Text property fields to the input table
  • Checked—Adds the list of CAD-specific Text property fields to the input table
  • Unchecked—Does not add the list of CAD-specific Text property fields to the input table
Boolean
Document Properties
(Optional)
Adds the list of CAD-specific Document property fields to the input table
  • Checked—Adds the list of CAD-specific Document property fields to the input table
  • Unchecked—Does not add the list of CAD-specific Document property fields to the input table
Boolean
Add CAD XData Property Fields
(Optional)
Adds the list of CAD-specific XData property fields to the input table
  • Checked—Adds the list of CAD-specific XData property fields to the input table
  • Unchecked—Does not add the list of CAD-specific XData property fields to the input table
Boolean
Derived output
Updated Input Table
The updated input table, feature class, or shapefile.
Table View
Environments
Current Workspace, Extent, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
