Excel To Table (Conversion Tools)
Summary
Converts Microsoft Excel files into a table.
Usage
Excel Workbooks (
.xlsx) and Excel 5.0/95 Workbook (.xls) formats are supported as input.The data type of a field in the output is based on the values and cell formatting of the entire input column and the limitations of the output table. Output field data types include double, long integer, short integer, big integer, text, date, date only, and time only.
Cells with dates will be categorized into date only, time only, or date (if they contain both time and date).
Numeric cells will be categorized as double if the values contain decimals; otherwise, they will be categorized as long integer, short integer (
.xlsx), or big integer depending on the magnitude of the value.When an output table type does not support the field type, the field type will be set to an equivalent supported field type. In this scenario, a double field type would be used in place of a big integer field types, and a date field type would be used in place of either date only or time only field types.
When an input column contains more than one type of data or formatting, the output field will be of type text.
A value of "#N/A" in an input Excel cell will be converted to null. If the output table format (such as a dBASE table) does not support null, another value (0 for integer fields or an empty string for text fields) will be used.
Parameters
| Label | Explanation | Data type |
Input Excel File |
The Excel file that will be converted. |
File |
Output Table |
The output table. |
Table |
Sheet Or Named Range (Optional) |
The name of the particular sheet or named range in the Excel file that will be imported. If unspecified, the first sheet in the workbook will be used. Named ranges are only supported for |
String |
Row To Use As Field Names (Optional) |
The row in the Excel sheet that contains values that will be used as field names. The default value is 1. The row specified will be skipped when converting records to the output table. If the Sheet Or Named Range parameter value is a named range, this parameter's value will be set to the minimum row of the named range. The value will also be limited to the minimum and maximum row number of the named range. To avoid using any row's values as field names, set this parameter to 0, which will name the output fields using the column letter (for example, If a cell in a particular column is empty, the output field name will be based on the column letter. For example, if the input has three columns, and the row contains "city", "", and "country" in columns A, B, and C, respectively, the output table's field names will be |
Long |
Cell Range (Optional) |
The cell range. This parameter is disabled when a named ranged is selected. If no cell range is specified, the tool will use the start and end cells of the specified sheet. A cell is the intersection of a row and a column. Columns are identified by letters (A, B, C, D), and rows are identified by numbers (1, 2, 3, 4). Each cell has an address based on its column and row. For example, the cell B9 is the intersection of column B and row 9. A cell range defines a rectangle using the upper left cell and lower right cell, separated by a colon (:). Cell ranges are inclusive, so a range of A2:C10 will include all values in columns A through C and all values in rows 2 through 10. The output field names are derived from cell values in row 1, regardless of the rows specified in the cell range. For example, if the cell range specified is B2:D10, the field names will be based on the values in cells B1, C1, and D1. The following are examples of valid cell ranges:
The following are examples of invalid cell ranges:
This parameter is only active when the Sheet Or Named Range parameter value is a sheet. |
String |
Environments
Current Workspace, Scratch Workspace, Output CONFIG Keyword
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
