Features To Graphics (Conversion Tools)
Summary
Converts a feature layer's symbolized features into graphic elements in a graphics layer.
Usage
  • Symbolized features are converted to graphic elements using the geometry of the feature and the symbol from the layer's symbology.
  • This tool is commonly used to convert only a subset (selection) of features to graphics.
  • Use the Exclude converted features from drawing parameter to exclude converted features from the Input Features parameter value from drawing so that only graphic elements draw in their location. To redraw converted features, view the feature layer's properties and check the exclusion setting on the Selection tab.
  • This tool does not support batch geoprocessing.
Parameters
Label Explanation Data type
Input Features
The layer to convert to graphics.
Feature Layer
Output Graphics Layer
The graphics layer containing the converted graphic elements.
Graphics Layer
(Optional)
Specifies whether the converted features will be excluded using a query.
  • Checked—The features will be excluded. This is the default.
  • Unchecked—The features will not be excluded; they will be preserved.
Boolean
Derived output
Updated layer
The updated input layer. The layer will contain the update of the exclusion set if the Exclude converted features from drawing parameter is checked.
Feature Layer
Environments
Output Coordinate System, Geographic Transformations
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
