Graphics To Features (Conversion Tools)
Summary
Converts a graphics layer into a feature layer with geometries based on the input graphics layer's elements.
Usage
  • Only one type of graphic element can be converted to features at a time.
  • Text elements will be converted to annotation. The full appearance of the element will be preserved.
  • This tool is commonly used to convert a selection (subset) of graphic elements to features.
  • If the Delete graphics after conversion parameter is checked, the tool will delete the graphic elements and new features will be drawn in their place. This allows the conversion process to be completed in one step.
Parameters
Label Explanation Data type
Input Graphics
The graphics layer containing the source graphic elements that will be converted to features.
Graphics Layer
Graphics Type
Specifies the type of graphic element that will be converted.
  • Point—Point graphic elements will be converted.
  • Polyline—Polyline graphic elements will be converted.
  • Polygon—Polygon graphic elements will be converted.
  • Multipoint—Multipoint graphic elements will be converted.
  • Annotation—Annotation and text graphic elements will be converted.
String
Output Feature Class
The output feature layer that will contain the converted graphic elements.
Feature Class
(Optional)
Specifies whether the converted graphic elements from the Input Graphics parameter will be deleted after conversion.
  • Checked—The converted graphic elements will be deleted. This is the default.
  • Unchecked—The converted graphic elements will not be deleted; they will be preserved.
Boolean
Reference Scale
(Optional)
The reference scale that will be used to convert text elements to annotation features. This parameter is required when the Graphics Type parameter is set to Annotation.
Double
Derived output
Updated layer
The updated input layer with deleted graphic elements if the Delete graphics after conversion parameter is checked.
Graphics Layer
Environments
Output Coordinate System, Geographic Transformations
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
