How Point to Raster works
The following information specifies how the cells are assigned values under various conditions when converting from a point feature class to a raster using the Point to Raster tool.
To control how a cell will be assigned a value, keep the following in mind:
  • If the points have m- and z-values, use the z-values.
  • If there is only a single point in a cell, that point's value is assigned to the cell.
  • A priority field is only used when Most frequent is used for the Cell assignment type parameter value.
  • If there is more than one point in a cell, the following apply:
    • If no priorities are set or the priorities are the same, the following apply:
      • If the attributes are different, select the point with the lowest Feature ID (FID).
      • Otherwise, select the point with the most common attribute. If there's still a tie, use the lowest FID.
    • If the priorities are different, the following apply:
      • If the attributes are different, select the point with the highest priority.
      • If the attributes are the same, select the point with the most common attribute; then select the one with the lowest FID if necessary.
  • If the feature lies on a cell boundary, the boundary rules apply.
Examples using different options for the cell assignment type
The image below shows examples for the cell assignment type.
Example of boundary rules for point feature to raster conversion
