Create Gaussian Splat Layer Content (Data Management Tools)
Summary
Creates Gaussian splat layer content as a 3D Tiles dataset from a (.ply) or (.lcc) file.
Usage
  • Level of details (LoDs) are generated for datasets without LoDs or recreated for datasets with LoDs.
  • The input coordinate system parameter will populate if the file contains coordinate system information.
  • For .ply files without a coordinate system or data origin specified, the origin will be determined by the input coordinate system parameter.
  • For .lcc files the coordinate system parameter will be populated based on what is specified in the metadata.
  • The .lcc format is a 3D Gaussian splat format developed by XGRIDS.
  • .lcc and .ply of type Gaussian splat is the only supported input type.
  • .lcc and .ply files in model space are not supported.
Parameters
Label Explanation Data type
Input Gaussian Splat File
The input .ply or .lcc Gaussian splat file.
File
Output 3D Tiles Dataset
The name output folder that will be created to store the 3D tiles dataset.
Folder
Input Coordinate System
The coordinate system of the input splat file. If the file contains coordinate system information the parameter will populate with that coordinate system.
Coordinate System
Data Origin
(Optional)
The x- and y-coordinate origin that will be applied to the input Gaussian splat.
Point
Z Origin
(Optional)
The z-coordinate origin that will be applied to the input Gaussian splat.
Double
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
