Post Version (Data Management Tools)
Summary
Posts a version.
Posting is the process of applying the current edit session to the reconciled target version during version geodatabase editing. Before a version can be posted, it must be reconciled with a target version and all conflicts must be resolved.
Legacy:
This is a deprecated tool. The Reconcile Versions tool should be used to post versions following a reconcile.
Usage
Posting synchronizes the edit version with the reconciled version and saves the data.
Posting can't be undone since you are applying changes to a version that you are not currently editing.
If the reconciled version is modified between reconciling and posting, you will be notified to reconcile again before posting.
Parameters
| Label | Explanation | Data type |
Input Workspace |
The ArcSDE geodatabase containing the edit version to be posted. |
Workspace |
Version Name |
Name of the edit version to be posted to the target version. |
String |
Environments
Current Workspace, Output CONFIG Keyword, Scratch Workspace
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
