Delete Reviewer Session (Data Reviewer Tools)
Summary
Permanently deletes one or more sessions and all related records from a Reviewer workspace.
A Reviewer session is used to store and manage the results of a data analysis throughout the life cycle of an anomaly. It allows you to organize the results from running batch jobs and visual inspections.
Legacy:
This tool is based on the Reviewer workspace which has been deprecated at ArcGIS Pro 3.7 and is no longer available. It is recommended that you migrate to ArcGIS Data Reviewer attribute rules-based workflows.
Usage
The Reviewer Workspace parameter value can be stored in an enterprise or file geodatabase.
When deleting a session from an enterprise geodatabase, connect to the Reviewer Workspace parameter value using the same version as when the session was created.
Use the Create Reviewer Session tool to create sessions.
Parameters
| Label | Explanation | Data type |
Reviewer Workspace |
The workspace from which the Reviewer session will be deleted. |
Workspace |
Session |
The Reviewer session identifier and name. The session must exist in the Reviewer workspace, for example, Session 1 : data_qc. |
String |
Derived output
Delete Reviewer Session Succeeded |
The result of the delete operation. |
Boolean |
Environments
Licensing information
- Basic: Requires Data Reviewer
- Standard: Requires Data Reviewer
- Advanced: Requires Data Reviewer
