Rubbersheet Features (Editing Tools)
Summary
Modifies input features by spatially adjusting them through rubbersheeting, using the specified rubbersheet links, so they are better aligned with the intended target features.
Illustration
Rubbersheet Features tool illustration
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • This tool is intended to be used after the Generate Rubbersheet Links tool. Rubbersheeting makes spatial adjustments to align the input feature locations with more accurate target feature locations based on the specified rubbersheet links. The input link features represent the regular links; the input point features represent identity links that hold source positions unmoved during the rubbersheeting process. Both input link features and identity link features must have SRC_FID and TGT_FID fields.
    All inputs must be in the same coordinate system.
  • The Method parameter determines the interpolation method used to create the temporary TINs in rubbersheeting.
    • Linear—This method creates a quick TIN surface but does not really take into account the neighborhood. It is slightly faster and produces good results when you have many rubbersheet links spread uniformly over the data you are adjusting.
    • Natural neighbor—This method is slower but is more accurate when you don't have many rubbersheet links and they are scattered across the dataset. Using the linear method in this case will be less accurate.
Parameters
Label Explanation Data type
Input Features
The input features that will be adjusted. They can be points, lines, polygons, or annotations.
Feature Layer
Input Link Features
The input line features representing regular links for rubbersheeting.
Feature Layer
Input Point Features As Identity Links
(Optional)
The input point features representing identity links for rubbersheeting.
Feature Layer
Method
(Optional)
Specifies the rubbersheeting method that will be used to adjust features.
  • Linear—This method is slightly faster and produces good results when you have many links spread uniformly over the data you are adjusting. This is the default.
  • Natural neighbor—This method should be used when you have few links spaced widely apart.
String
Derived output
Modified Input Features
The updated input features.
Feature Layer
Environments
Current Workspace, Extent
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
